Average cost on ls conversion
Old Oct 26, 2010 | 02:56 PM
thebigkeebler's Avatar
Default Average cost on ls conversion
I'm just about done with my 67 camaro just started going through the receipts and I cant believe what I got in the deal already and not done yet. I just built a mild ls1 and all I had to buy for the nos was the plate I had every thing else and I'm still at $9800. And only $1500 for that is labor witch includes rewiring the whole car. Is that about average or did I buy to many parts?
Old Oct 26, 2010 | 03:13 PM
speedtigger's Avatar
Old School Heavy
I don't know that there is an average cost. There are a gazillion variables.
Some guys buy mounts and some make them. Some guys bend up a factory style metal fuel line while others need the latest braided line with the best fittings. Some guys use the exhaust manifolds and tie it into the existing exhaust system while others buy the best headers and an all new 3" stainless exhaust. etc etc etc. There are simply too many variable to say average cost.
Old Oct 26, 2010 | 03:28 PM
98SuperchargedLs1's Avatar
i wish there was an average price.. i have a 65 chevelle doing a ls2 with a single turbo all custom.. custom manifolds, 4inch stainless exhaust, built 4l80e everything is new no used stuff except the 19k mile motor i bought.. i will probabaly be up in the 15-20k range by the time im done
Old Oct 26, 2010 | 03:33 PM
71ANTICARB's Avatar
^^^What he said but I am doin a lq4/t56 swap in my chevelle lookin at less than $2500.
Old Oct 26, 2010 | 04:27 PM
gheatly69's Avatar
I'm about half way through and I'm looking at around $10k, less $2,200 I made on selling parts off the GEN I small block in the car. I'm installing a bone stock L-92 from an Escalade. Hopefully, I'm not going to have any major issues jump up that are going to cost a lot to fix. Amazing how fast it all adds up!
Old Oct 26, 2010 | 05:31 PM
zamora7's Avatar
I'm right about $4000 including car, motor, tranny, 4th gen seats, 4th gen radiator and cooling fans, sandblasting and por-15, mounts, bushings, qa1's front, steering linkage, and wheels on a second gen T/A.
Old Oct 26, 2010 | 05:45 PM
chevyboy91188's Avatar
I bought a 36k l33 motor and longtubes for my chevelle swap and custom harness and didn't even break 2k so it all depends on what you run
doing things yourself helps cut cost alot too
Old Oct 26, 2010 | 06:50 PM
Pocket's Avatar
Under $2k here too
Its the mods, labor and cut corners done twice that kill the budget
 Michael S. Palmer
Old Oct 26, 2010 | 07:04 PM
Gray86hatch's Avatar
I am keeping a list on my dads l76 carb swap. I didn't need any fuel system stuff other than a carb.
bought a 125 mile l76 swaped cam, lifters, dod, springs, intake.
Headers and carb, alum radiator.
we have spent about $5000 and have about everything we need. Poss a pan and pu.
The bbc we are taking out should bring about $5k so it is not a bad deal for him.
It is not cheap depending how far off the deep end you jump.
Tim
Old Oct 26, 2010 | 08:26 PM
kdavis's Avatar
Ive got about 2500 including the car, motor, trans, 5lug swap and wheels. i still need harness, k member and a few other small things
Old Oct 26, 2010 | 08:32 PM
STEEPSS's Avatar
My goal for my 280z is to have > $2500 out of pocket, and have it on the road.
Old Oct 26, 2010 | 10:10 PM
zamora7's Avatar
Originally Posted by Pocket
Under $2k here too
Agree on the mods. Well, idk if I should call them mods or maintenance since when I bought the car it had not been driven for about 9 years. Bout the qa1, the steering, bushings for body, and suspension, and the wheels. Thats maybe 1200 or so.
Old Oct 26, 2010 | 10:11 PM
Smo's04Gto's Avatar
swapped a ls1 6spd into my nova running and driving for about $3,500
Old Oct 27, 2010 | 08:39 AM
Jim_PA's Avatar
Should be easy to achieve your goal
Old Oct 27, 2010 | 09:18 AM
c6matt's Avatar
its all about the "while i'm doing this, i might as well.." I had about 10K in the swap(before the blower), but that included a built 8.5" 10 bolt, a custom harness, new springs, 4l60, cable x speedo adaptor..s&p headers, magnaflow exhaust, conversion oilpan, spectre tank.. ect...
the as long as i have a good running ls1 i "might as well" supercharge it
Now I'm at...
now that its supercharged i "might as well" put in a 4l80/built 4l60
Old Oct 27, 2010 | 10:14 AM
jfg455's Avatar
I have done 7 swaps into 88-98 chevy trucks (2wd and 4wd) and S10's (2wd) and our average cost is $4300-$5800 depending on options IE: 5.3L vs 6.0L, keeping the old tranny, A/C, etc. Includes new fuel pump, fuel lines, radiator and heater hoses etc. Turn key out the door. And that is only $1500-$1800 labor. Comes with a drivable tune as well. Dyno tune is extra. just my $.02
We did a 6.0L T76 turbo in a 99 mustang for $9200 out the door. No A/C, modded the TKO500 ford tranny to fit the LS motor etc.
At the same time I did a 5.3L swap into my own 88 K3500 for $1760 total.
Old Oct 27, 2010 | 10:45 AM
oldngray's Avatar
X2 for speedtigger--- to many variables and different sized wallets
Old Oct 27, 2010 | 12:28 PM
STEEPSS's Avatar
Believe what you want. Bought the car for 1500, sold the SBC and mount kit for 1450. So far I'm in $50. . Deal with it.
Old Oct 27, 2010 | 02:15 PM
with only a 5.3 you can easily so it for less than 2500 heck you could even put a cam in it while ur at it and make it. its all about patience good things come to those who wait (if they are smart enough to know when its good and not let it pass). If I can do an l33 with custom harness with stainless headers in my chevelle for less than 2k a z swap can be done for less than 2500
Old Oct 27, 2010 | 04:14 PM
dville_gt's Avatar
the "i might as well go all out" attitude has increased my project cost 10 fold
