Specific Mustang swap k-member question.
I am doing a 6.0 conversion on my 90 mustang hatch and I got a screamin deal on a UPR 4.6 swap fox k-member. I know the stock 4.6L k-members will work for this swap with stock manifolds. But my question will this UPR k-member work with Dynatech or Kooks headers? Has anyone tried this peticular type of k-member setup? Thanks in advance.
Other than that you are having some built or doing the whole welding 351 headers onto the LS1 flange nonsense.... Not a big fan of the latter. Just seems to be a lot of work for the end result....
Hope that helps.
That sucks. I got this k-member for $100 hoping I could make it work.
So you are saying the Kooks and Dynatech headers will hit the flat mounts that the 4.6 mounts use?
Thanks for the input guys. I've been looking at the BRP headers too. But you are right, they are awfully high.
I've done a couple foxbodies with aftermarket modular k-members without issue. One thing you will need to do when going this route is to extend/lengthen the steering shaft as the 4.6 kmembers put the rack further forward than the 5.0 cars. I cut mine and added a small length.... Works fine and likely stronger than stock. LOL for late model cars this isn't needed though. 94up....
