Range Rover LS Swap
Old Jan 5, 2015 | 02:19 PM
leftlanetruckin's Avatar
And an example of something real and relevant .....
https://ls1tech.com/forums/conversio...nge-rover.html
Old Dec 26, 2017 | 05:04 PM
John R Siebert Jr.'s Avatar
Default 2011 Range Rover LS1 swap
Has anyone here repowered the original Range Rover 5.0 with a GM 6.0?
Old Sep 11, 2020 | 09:38 PM
Vin Galo's Avatar
Default Hello
Hello man, how are you? I want to do the Ls swap can you please make me a transfer case adapter?
Or transmission adapter??
Old Sep 12, 2020 | 01:08 AM
None of these guys have been here for years. Always check post dates.
Old May 2, 2025 | 04:41 PM
adventure's Avatar
Hello my friend, I am a new member. I am happy to join the forum. I am a Range Rover P38 owner. Can you help me?
I have a range rover p38 can i buy some stuff . ls sump range rover p38 . ls range rover headers ceramic coated . 6l80E to p38 Borg Warner Adapter and spud shaft . ls engine mount kit . auto neutral park & ​​reverse kit.
Old May 4, 2025 | 04:06 PM
adventure's Avatar
Originally Posted by TheStache
I had seen some posts here or there on this...has anyone on Tech completed this swap? I found an Australian site that has some conversion parts, which will help, but I still have a lot of unanswered questions before I commit to this. I was looking to use either an LS1 or 5.3L with some mild upgrades and refreshing and a '96-'01 Rover (auto trans). I'd like to keep the 4WD but it is not crucial. Overall goal is to have the simplest and most reliable setup.
1) There are parts to adapt to the factory trans, but I was wondering how the trans is controlled and whether this is an issue with an entirely different motor and PCM.
2) Will this trans be able to hold up to the extra hp/tq, especially if I am towing (open trailer with Camaro racecar)?
3) Is there any way to connect the transfer case (4WD system) to a GM trans, and if not...is there any issues to not doing so besides the obvious loss of 4WD?
4) Any way to get the factory gauge cluster to work? If not, could I drop in an old F-body one or am I stuck with building my own cluster out of Autometer gauges or an expensive Racepak?
5) Does anyone know what oil pan and accessory drive setup is preferable? I could figure that out if need be, but of course it would be nice to know ahead of time. Looking to stay with factory parts if possible.
Hello my friend, please can you help me how to contact Australian sites to do conversion?
