LS6 vs BBC 396 I need HELP making a Decision!!
It has no motor, tranny, fuel lines or factory bb engine harness under the hood is basically a shell with all steering stuff (power steering) rebuilt and thats it nothing else
So basically what im trying to figure out is should I do an ls6 conversion or go big block. I know the benefits etc of the ls1/ls6 motors and really want to go this route but im just worried if i run into some unexpected problems with the swap I may end up running out of money.
Almost everthing i would have to buy for the LS6 i would have to buy for a bb 396 as well so i feel like i may as well just go with the ls6 budget is about 7k which is gonna cut it VERY close
from my engine guy, rebuilt 396 with hydrolic rollers cam kit rebuild kit machine shop work price core motor block etc... also m21 muncie 4sp
3000 $
still need radiator, fan, fuel lines, exhaust, clutch, clutch resevoir p/s, alt, distributor, intake manifold, carb, engine harness, etc im sure there is stuff i missed. Like i said under the hood is basically a shell with all steering stuff (power steering) rebuilt and thats it
or
COMPLETE 2004 cts-v with t56 6 speed
complete with all belt driven accessories, starter, exhaust manifolds, MAF sensor and elbow, fuel injection,. Complete from fuel injection to oil pan. TAC module and throttle pedal included as well for "drive by wire". Transmission includes pedals, driveshaft, hydraulics and shifter. Wiring harness NOT INCLUDED but ECM is included
4000$
00$- hoping that cts-v oil pan will clear ??? input??
50$ s&p style motor mount adapters for ls1 w/ old style motor mounts
-wiring
529$ psi ls6 stand alone drive by wire harness (not sure what 24x crank
reluctor is ??)
300$ ecm Flash
some of ilove1stgens's price list
-Fuel
500$ spectre tank with in tank fuel pump
37$ 023-FCA0410 10 feet of 4an feul line -jegs
77$ 023-FCA0620 20 feet of 6an feul line $77-jegs
40$ 710-65385 return line kit $40-jegs
50$ 99 vette filter/regulater $50-napa
-Cooling
190$ GRI-1-25272-X Griffin crossflow radiator $190-summit
16$ SUM-380100 Mounting brackets $16-summit
119$ FLX-398 electric fan $119-summit
-trans
349$ ATS adjustable t56 crossmember
80$ ATS clutch master firewall bracket
00$ motor comes with clutch pedal assy hoping this will work??
-exhaust
00$ factory cts v mainfolds hoping this will work???
200$ cut drive shaft to proper length
$6537
will worry about gauges later just want to be able to get this thing up and running
Things offsetting the price of the ls6 conversion because they would have to be bought anyways to get the big block running
500 approx> All Accessories for the bb 396 would have to be bought
500 headers,
125 factory fuel lines,
200-300 radiator
125 engine harness
400 clutch
200 driveshaft
2100
+ 3000 for the motor and trans
5100 appox to go with the bbc 396
I know 1500 doe'snt seem like a lot and I should just upgrade but I will literally have only 500$ left in my account if I do the ls6
1 just curious what everyone thinks
2 Please give me some feedback on things I may have missed or things that will/will not work with my planned LS6 setup
You obviously want to do the ls swap. Keep saving and do it. Dont just do something different cause you can't afford to do what you want right now.
I've spent 6 years on my 1971 olds 442, upgrading it as I get money.
Don't do what is cheaper cause you can afford it now and end up regretting it later.
http://www.jegs.com/webapp/wcs/store...inum+fuel+line
If you locate the regulator at the back of the car you can use a simple rubber hose return line cost about $2. It's low pressure and no one will ever see it. I am also thinking you should be able to modify or relocate your current trans cross member and save some money there. I got a universal one from Comp Engineering. Jegs also has them, less than $100.
http://www.jegs.com/webapp/wcs/store...94966286&Nty=0
Read through the Stickys above, you don't have to spend that much money if you can fabricate even a little bit.
In the long run I think you would be happier with the LS6. It would be much more pleasant to drive and less expensive to operate.
Good luck with your swap, lots of first gen experience here to call on.
Pat
I would go ls6/t56, reasons would be:
Gas mileage, i know most people don't care so much for their project cars, but i like to drive my cars as much as possible, and i commute 60-70miles daily.
Driveability, idk how a muncie 4sp feels, but with my limited twice around the block experience with a t56 it feels very smooth.
Lastly the grin factor when you pop the hood/ step on the gas.
I had a pretty strict budget for my hot rod, then realized i could never build it they way i want to. Might be a year or so longer before its 100% finished, but atleast i won't regret anything.
Whatever LSx engine you choose will run circles a little 396, have better drivability, and get better gas mileage.
Muncies are sweet shifting transmissions. Better than a T56. If you want, you can keep it. A wide ration Muncie with a 3.31 gear should work fine and not be too terrible on the highway.
Andrew
What is rock auto? I see that tank listed on there is this a pretty good site. Ive never heard of them until today. Im about to pull the trigger on that tank just want to make sure that they are reputable.
Here is an example of one I just found:
http://www.dslreports.com/forum/r217...e-for-RockAuto
Pat
