Hot rod impala ss 1964 5.3 swap
I got this 64 impala ss project i am building it on a budget... I bought it with no motor and trans. I am going to do the body work my self and paint.It has some major rust on the floor but not a problem to fix.... i just bought a 2004 5.3 swap with 4L60 trany and ecu....I am going to do the swap my self i need some help!!!! Where to get a web page on how to do the wiring harness...i want to swap the intake to a Corvette or Camaro FUEL RAIL and i think i have to change the throttle body too to a mechanical cable.. What else do i have to change to make it work ?
A 2004 5.3 should be a 24X reluctor engine. Go to www.lt1swap.com....he has all the wiring info, complete with pictures to rework your 5.3 Vortec harness yourself. It's really not that difficult. I'm sure glad it's you instead of me starting on that bodywork project, LOL. Good luck! Ron
https://ls1tech.com/forums/conversio...chematics.html
might help you out.It's not for the year of engine your using, but at least you can read up abit and gain some knowledge. Where you getting your body parts from?
Started on my 2 weeks ago same thing 64 with 2000 5.3 I had to buy f-body oil pan,intake manifold all the front acc.(front pulley wp,alternator bracket ps bracket) heads up get the brackets from dealship cheap i paid 20 for alternator bracket 15 for ps bracket. using standard swap plates for mounts.Moved transmission crossmember back 2in.
Im so glad it will be a hot rod impala and not a low rider.
Pomona will be a good place to find a lot of parts. I go there all the time.
All that rust looks scary. Good luck with the build and take a lot of pix.
