Stainless fuel lines
Old 12-26-2010, 01:13 PM
FALCON's Avatar
Default Stainless fuel lines
I hate asking questions and usually get all my info from searching but I can't find anything on this specifically. I am setting up my fuel lines and would like to order what I need. I plan on running stainless hard line from the FPR to engine and then 30R9 fuel injection hose from the end to the fuel rail and from the FPR to the tank. Will barbed fittings with two fuel injection clamps hold the pressure and on the engine side of the hard line can I just double clamp the hose on the end or should I use some type of fitting? Thanks in advance.
Old 12-26-2010, 01:27 PM
sierrac3_s2000's Avatar
I used the Dorman fittings double clamped for the rubber hose from the FPR back to the tank. Then I used stainless hard line from the rear to the front. On the stainless hardline I used a hydraulic flaring tool to put the GM quick connect flare on the SS line. At the engine compartment I used Teflon lined braided line with the GM quick connects on both ends. It has worked flawless for me for over two years.
