LQ4/Turbo swap into a 1981TTA
Old Mar 19, 2012 | 08:31 PM
  #81
Rick Speed's Avatar
You will need more timing for sure and get the AFR right. I'd find a Mustang dyno and tune it properly. And with this kind of set up you really should have a pro help out. I've seen some first timers really mess things up.
Old Mar 21, 2012 | 12:13 AM
  #82
MillsMotorvation's Avatar
Originally Posted by pitbull14218
Nice build, I don't know if I missed it, did you use the truck accessories too?
Yes, all the parts from the truck.
Old Mar 21, 2012 | 12:16 AM
  #83
I agree, I talk to Steve at Frost, Im hoping he will give me pointers. Can you recommend any books that may help me with tunning(HP)
Old Mar 27, 2012 | 09:22 PM
  #84
Well I ordered the HP Tuner Pro from Frost! Anyway took the car out to see if I could make a full pass using my G-Tech. The first pass was to the 1000ft, and the car ran a 11.08 110mph@4566rpm! Thats with timing on 7.5*, and fuel on the wide band 9.5 during WOT. Showing no KR, thats with meth kit working. Anyway that small pass showed the weakness, of the car, and my stupidty the rearend started humming. Checked the rear dope, it was dry! They dont sell a clutch&Plate kit for that rear, so getting a Locker unit installed, and the sub frame connectors. Also had a friend port the TB, and the car felt stronger, thaat was on the car before the test pass.
Attached Thumbnails LQ4/Turbo swap into a 1981TTA-cell-picture-video-173.jpg   LQ4/Turbo swap into a 1981TTA-cell-picture-video-192.jpg
Old Apr 26, 2012 | 07:51 PM
  #85
Update!! Well, got the snow kit on, got HP Pro kit installed, and Steve at Frost has been giving me updates to tune the car in. He's a busy guy, but he found time for me, and my God, I was thinking the car ran good, but every update he sent me the car almost picked up a second in the 1/4mile . I send him a scan,and he tells me hes making updates. Well I cant try the last update because my new posi is making a noise, or the gears are dieing, I didnt change them. By my G/Tech the car went from 112mph to 116mph to 118mph to 123mph! Thats with leaving at idle, so I cant imagine what the next updated will do, but got to get the rear fixed! The wideband is working great(LC1). He told me Im short shifting, because im shifting at around 5000-5500. I built this car cause my dad would be proud, and I couldnt afford a ZR1, think Im going to be happy with my 1981Turbo Trans AM.
Old May 3, 2012 | 11:15 AM
  #86
Well took the car back to the exhaust shop because they screwd up the exhaust, I left the car there. When I came back it was on the ground didnt get under there to look, so I saw the 2 tips were where I wanted, I assumed they had they Y correct, until I did the brakes I saw the mess. Anyway took it back, and watch them, it flows better! Put Manaflow mufflers on the car, its so quiet! Took it from there to the paint shop, and the car is getting done back to what ti would look like original, except Im using the white off of my 07 GMC Sierra!
Attached Thumbnails LQ4/Turbo swap into a 1981TTA-cell-phone-pics-vid-061.jpg
Old May 7, 2012 | 09:44 PM
  #87
Default Video if I can do It!
The cars coming along good, hurt the rear waiting on ring&pinion, turbo blanket, and LS9 HGs.
Old May 8, 2012 | 05:07 AM
  #88
2nd Gen Fl 'bird's Avatar
Curious as to what Magnaflows and how it or they were installed. I want quiet too.
Old May 8, 2012 | 10:58 PM
  #89
muncie21's Avatar
Originally Posted by Poncho72
I'm glad to see this build also, only successful swap i've seen without using ls1/2/6 intake and truck accessories. curious if anyone else has done this successfully. i too am planning a 6.0 lq4 swap in my 72 T/A clone, have been reading posts on all the hiccups and headaches when making it all fit. i know i will need to move the A/C compressor and swap the oil-pan etc... in the swap. i'm very "LS" green so before i tackle my build, i am doing a lot of reading and researching.
Another Trans Am transplant fan watching this thread with interest. Hoping to get a LQ4/9/LSx installed this summer.
Old May 9, 2012 | 01:26 AM
  #90
Thanks, Im glad I did it. The little things are what slow you down! This is as close as I could get to a Vette. Thinking I should change to a 5.3 cause they dont need much to live at high boost, where I read the 6.0 needs rods, and pistons.
Old May 9, 2012 | 08:11 AM
  #91
Jimbo1367's Avatar
Why is this? Pistons should be basically the same, minus the bore size. Rods depend on yeAR
Old May 13, 2012 | 10:10 PM
  #92
Yea but all Ive read shows rods in the 6.0 wavey. Ive started getting the 5.3 ready waiting on APR rod bolts, and head studs. Also installing LS9 HGs to hold the boost in. Theres a article in HOTROD where they hooked 2 76s to a 4.8, but they thought it was a 5.3. all they changed was cam, and heads took it apart, and gap the top rings, and put a Comp281 cam. Made 1203 Hp at 26psi over a 1000 hp at 11psi, and showed no sign of blowing, so thats the way im going, 6.0 will be out by the weekend.
Old May 14, 2012 | 12:43 AM
  #93
1961ba427's Avatar
Are you going to keep the 6.0 for a backup?
Old May 14, 2012 | 08:41 PM
  #94
yea. until I can get good rods, and pistons.
Old May 15, 2012 | 03:41 PM
  #95
joeyc125's Avatar
11 Second Truck Club
Don't pull that good running 6.0 for a 5.3!! That 6.0 will live fine at 600+rwhp and run you high 9's with traction. The guys bending stock rods under that hp level are probably trying to run too much timing. Timing kills rods and head gaskets much faster than a little less timing and higher boost. 5.3's can make great power, but will have the same rods unless it's an 05 or newer, even then, the factory "stronger" rods are pretty heavy. Just run it how it is! Ls9 head gaskets and head studs are all I would do to the 6.0 until you want to run ALOT faster than you are now.
Old May 20, 2012 | 03:02 PM
  #96
Thanks alot, I already pulled it. I run a 87 GN and the small cube engine can handle more boost. Also the turbo will be bigger on the 5.3. Just wanting to try it to see if it lives. Theres a guy running a 5.3 with 9psi going 10.60s. Im hoping for 10.0s on 14psi. Ported my heads, and manifolds, studs are in waiting on rod bolts!
Old May 21, 2012 | 07:14 PM
  #97
Rod bolts arrived today, and Im ready to set it in!
Old May 22, 2012 | 02:16 PM
  #98
Razor's Avatar
Thanks for keeping us up to date with your progress.
What did you use for your fuel system in the car?
Old May 23, 2012 | 07:24 PM
  #99
Truck rails, added a Areomotiove boost referenced regulator. Summit inline pump, 60lbers, and a snow meth kit. Car was way rich had to pull a lot of fuel! Got the egine, and trans connected, added the oil cooler from the truck, I found it helps alot when running a turbo.Use the 4way water air bypass for the heads.Everything off the other engine on there.
Old Jun 5, 2012 | 01:09 PM
  #100
BMF_Racing's Avatar
Thumbs up
Looks good, getting ready to tackle this same project in my brother's '80 TTA. Keep the pics coming.
