Stans 1968 camaro LS swap and other upgrades!
#783
I like it. This style of SC (vs. Maguson) is starting to grow on me. What did the supercharger cost? Anything missing when you got it?
Thanks,
Jim
Thanks,
Jim
#788
Here is the stock pump hat that came with the tank.
Here is a pic of the tank a few years ago when I bought it..
Now I have to pull my gas tank and build a new fuel hat so I can use two pumps..
#789
#790
My original ricks fuel pump hat only good for one pump
Cut out the lines and laying it out for two send Lines from two pumps and a return line
Had to make isolator for the power for each pump
Primed
Painted
Primed
Painted
#792
I was going to suggest you checked the pump wiring, but you redid it anyways. Looking good !!!
#795
Had to cut the opening bigger to fit both pumps through.the old setup used a o ring to seal and I had to cu into the o ring area so I’ll need to make a different gasket ..
#799
What size Y you running?
