Initial Start Up Exhaust
Old Jan 26, 2011 | 05:50 PM
darksider's Avatar
Default Initial Start Up Exhaust
I have a question about what exhaust you used for your initial start up after the engine swap. Did anybody tow the car to get the exhaust installed first, or did you just put some straight pipes on the headers or exhaust manifolds? I ask this in regards to the O2 sensors, where did you put them if you did not have a full exhaust.
I am putting an LS1 from an '04 GTO into a 65 GTO and I am plannig to use F-body exhaust manifolds. Thanks in advance,
Mike
Old Jan 26, 2011 | 05:59 PM
Tony C.'s Avatar
I started mine a few times with just the headers on no 02 sensors.They were installed later with the exhaust.
Old Jan 26, 2011 | 06:11 PM
gofastwclass's Avatar
I've always run mine with open headers and O2's in them. Then I do the really trailer trash thing and drive to the exhaust guy. My neighbors love me, hahaha!
As shown...
http://www.youtube.com/watch?v=TNSw9Q0P3Dk
aknovaman's Avatar
If you can drive the car a short time before the engine warms up and goes into closed loop mode you would be ok as in open loop it ignores the 02's anyways. If the engine goes into closed loop, the PCm will see 450mvolts and read that as lean and dump tons of fuel all over the bottom side of your chassis. Just rent or borrow a trailer or tow dolly. Not worth getting the whole bottom of the car all dirty with raw fuel.
Old Jan 26, 2011 | 06:17 PM
Why do you have to rain on my parade AK? J/K My exhaust guy is really close so it's not a big deal but it also depends on where the O2's are located. If they're at the end of the headers, no dice but on my Thunderbird they were really close to the engine and I have a long ways before the end of the collectors.
Old Jan 26, 2011 | 06:18 PM
MillsMotorvation's Avatar
I drilled holes in the stock manifolds, and weld O2 bungs!
Old Jan 26, 2011 | 09:09 PM
Pocket's Avatar
I fired on open manifolds sans HO2s but only ran it a few seconds before building the rest of the exhaust
No HO2s will only throw a code if allowed to warm up
Old Jan 27, 2011 | 09:18 AM
lizeec's Avatar
Default Raw Fuel???
So let me get this straight you are saying if the engine goes into closed loop mode it will dump tons of fuel on the bottom side of your chassis?? So if you have a o2 fail or damaged wiring it will go into a closed loop mode and dump tons of fuel as well?? And exactly where does this tons of fuel come from within the fuel system?? Do you think that just maybe that would be a HUGE LIABILITY issue(you know the HUGE FIREBALL that is coming next) with General Motors?? Get real, and people need to take a lot of this information given on these forums with a grain of salt!
Old Jan 27, 2011 | 10:10 AM
BR3W CITY's Avatar
Only thing I can think of is that he's assuming its tons of unburnt fuel getting sprayed out of the open headers onto the chassis. If thats not it, then I don't have a clue how that would happend.
Usually if you have a failed o2, it will just pop the CEL and run like crap.
Old Jan 27, 2011 | 01:15 PM
darksider's Avatar
Thanks for the replies. I think I'll tow it to the muffler shop and get the exhaust put on, then I'll be set.
gofastwclass, great vid, do you have more?
Old Jan 27, 2011 | 01:38 PM
rockytopper's Avatar
I am running stock manifolds. I had to plug the driver side o2 port in the manifold it hit my frame. I purchased the mating flanges off the cats from a salvage yard took them to the same place I had planned to do my exhaust. I had them weld some short straight pipes to the flanges with O2 bungs I took them. I then finished the swap drove it to the same shop weeks latter and they finished the rest of the pipes starting from the short sections I had already installed. I live in the sticks so the noise was not much of an issue. I also white trashed it 14 miles to the muffler shop.
What can I say I really white trashed it on my first test drive
COUNTRY BOYS CAN SURVIVE.......................
http://s282.photobucket.com/albums/k...t=MOV06596.flv
Old Jan 27, 2011 | 02:17 PM
warpdriv's Avatar
Speaking of O2 sensors, where is the best place to put them? I was thinking of putting mine in the header right above where the collector bolts on.
Old Jan 27, 2011 | 04:23 PM
darksider's Avatar
Great video, Rocky. The best part is the camera falling the dash!
Old Jan 27, 2011 | 04:43 PM
79LS1FOX's Avatar
I love the big old C clamp, you could use it to take aim at pedestrains....LOL
