Shift Cable too short??
Old Jan 31, 2011 | 03:28 PM
T/A KID's Avatar
Default Shift Cable too short??
Guys doing a Mid-engine project with a Gm LS engine and Audi 5-speed automatic. To make sure the shifting works like it should I have planned just to use the Audi automatic shifter, but the shift cable is way to short to use since its in the rear of the car. Don't know a lot about shifter cables, or if they are specific for each vehicle?
What should I do?
Old Jan 31, 2011 | 11:45 PM
G-Body's Avatar
sawzall wielding director
They are usually specific to the car, but theres no reason you can`t modify the shifter/brackets to let a universal one bolt in. Hit up B&M or even an industrial supply house and you should be able to find one that you can make work.
Old Feb 1, 2011 | 11:01 AM
Andy1's Avatar
You can order custom push-pull cables from McMaster-Carr. The source I prefer however, is Control Cables Inc. Knowlegeable, and a CC by phone and they'll ship. Though I doubt either of these sources will have Audi specific bulkheads, some minor adapting should be pretty straight forward. I've done several cable shifter adaptations, so let me know what specific question you have. I'm currently doing a mid-engined LS1/Audi 6 speed conversion.
Andy1
Old Feb 1, 2011 | 04:41 PM
T/A KID's Avatar
Thanks guys, the cable I have is about 17inches long, needs to be atleast 2x that, so I'll look into these options.
Anydy what bellhousing you using? Since my setup uses an automatic trans (same bellhousing as manual) I think I am just going to make my own. I'll have the trans shortly.
Old Feb 1, 2011 | 06:17 PM
Andy1's Avatar
T/A KID,
This guy makes adapter plates for LS1/Audi manual 01E trans applications: http://www.kitcarchassis.com/
Andy1
Old Feb 1, 2011 | 09:55 PM
T/A KID's Avatar
Andy thanks, I actually know him thats Eric, hes on the GTM forum with me. I know Kennedy builds them too.
Old Feb 1, 2011 | 11:03 PM
G-Body's Avatar
Is the Audi 5 speed transmission used in any vans? I know the GM vans have very long shifter cables.
Old Feb 3, 2011 | 11:54 AM
T/A KID's Avatar
Nope just used in the BMW, VW, and audi cars (all roughly the same size) requiring the same length. When I get more involved with the swap I'll let you guys know.
Thanks
