Solid vs. OEM vs. Poly motor mounts
Old Feb 22, 2011 | 08:02 AM
borrone821's Avatar
Default Solid vs. OEM vs. Poly motor mounts
Hey guys,
I'm dropping an LY6/T56 into a 69 GTO and am trying to figure out what mounts to use. I've been told I need to get chevelle frame stands one way or the other, that BOP frame stands do not work.
I like the dirty dingo slider mounts, but they're solid mounts, whereas I'm reading that most people use the Edelbrock, S&P, or BRP mounts with poly bushings.
Can anyone give me a quick rundown of why people use one over the other?
I'd like to buy my adapter plates, mounts, and frame stands this week so i can test fit my motor next weekend or so.
Thanks
Jim
Old Feb 22, 2011 | 09:55 AM
jmilz28's Avatar
I can share my experience in my 4th gen Z28, maybe that will help.
I wanted strength and not to have to worry about replacing motor mounts, but it was a DD - so I went poly.
The tranny mount was poly too but vibration was AWFUL! Went OEM on the tranny mount and was close to stock comfort. My shifter didn't move at all with poly/poly but only a little with the OEM mounts. The fact that the tranny mount is MUCH easier to change sold me on this combo. This was with stock cam so it would have been worse with the cammed motor.
I would think this translates to your platform somewhat. If you care about comfort and the option to put some miles on it, I recommend the poly/rubber combo.
Old Feb 22, 2011 | 10:10 AM
borrone821's Avatar
Thanks for the input jmilz.
I was reading the other day about some people that claimed solid mounts resulted in less overall vibration.
everyone says the poly trans mount is a must.
If anyone else can weigh in, I'd love to hear about it.
Jim
Old Feb 22, 2011 | 11:12 AM
xpndbl3's Avatar
If he had vibration with the poly mount he should have his driveshaft rebalanced/checked. I run solid mounts and poly trans mount with no vibration at all
Old Feb 22, 2011 | 12:47 PM
Pop N Wood's Avatar
I would caution against mixing solid and rubber/poly anything. Datsun Z cars are notorious for having a poorly engineered front diff mount (IRS rear). It is very tempting to put a solid front diff mount, but then keep the rubber or even poly rear diff mounts. The problem with that is the rear can wiggle a bit whereas the front doesn't. What eventually happens is the solid front mount cracks the front diff cross member resulting in some pretty impressive carnage.
Maybe solid motor mounts and poly trans mount is different, but I would still think going all one way or the other is the way to do it.
I tried a solid rear diff mount on my Z once. It transmitted so much gear noise into the car that I felt physically ill after 10 minutes. It was all high frequency gear noise and not driveshaft vibration. Different car and a worn diff, but I wouldn't lock myself into a solution that can't be switched to something else if need be.
Old Feb 22, 2011 | 01:37 PM
borrone821's Avatar
Thanks PopNWood.
So does anyone have experience with dirty dingo LS Mounts? Either the solid mounts, or the new sliders.
Old Feb 22, 2011 | 07:41 PM
Z33Art's Avatar
I second that! I run solid and I love it! Minimal vibration.
Old Feb 23, 2011 | 01:39 AM
xpndbl3's Avatar
has nothing to do with what we're talking about here.
Old Feb 23, 2011 | 06:47 AM
Pop N Wood's Avatar
You're not talking about putting a solid mount on one end and flex mount on the other?
Old Feb 23, 2011 | 10:30 AM
xpndbl3's Avatar
There are no cracking issues like in a solid mounted rear end that you were talking about.
And if you didn't put a poly mount on the trans with the solid motor mounts you would crack the trans bellhousing from chassis flex since a solid trans mount would not flex so the case would. Thousands of people run solid motor mounts with poly trans mounts on the dragstrip everyday with no issues.
Old Feb 23, 2011 | 01:19 PM
Pop N Wood's Avatar
Cool. Like I said I wasn't sure.
Old Feb 23, 2011 | 10:19 PM
devlmaycry's Avatar
I think it all just depends on what you want out of the car. I know most people like the poly because they are more durable and less prone to failing than rubber. Though they tend to transmit more vibrations through the body than rubber. Doesn't matter what anyone says they do it's just all perspective on what your comfortable with. The solid I'm not sure about. I know I have ran poly and rubber in my car and I def prefered the rubber. Same with my buddy and his 02' Camaro Ultra-Z with a 427 swap in it.
Old Feb 23, 2011 | 10:34 PM
tripblackls1's Avatar
this is only true if you have a trans mounted torque arm, if you have a body mount ta or no ta then there is no need for a poly trans mount as there no torque or movement on the trans its self
although if you run a poly trans though with rubber motor mounts you do have a potenal to crack the trans as the trans is mounted without flex and the motor flexes with the rubber mounts
Old Feb 23, 2011 | 10:35 PM
i prefer soild mm with rubber trans unless using trans mount ta
Old Feb 24, 2011 | 01:18 PM
xpndbl3's Avatar
No you can still snap a rubber trans mount with poly motor mounts, I've done it in the past, and trust me there is still a large load on that mount regardless of the torque arm being mounted elsewhere.
Old Feb 24, 2011 | 06:31 PM
Tainted's Avatar
had all poly mounts in my 99 t/a and it vibrated some but not bad
Old Feb 24, 2011 | 07:09 PM
STEEPSS's Avatar
Poly motor mounts, Rubber trans. FTW
Old Feb 25, 2011 | 07:49 AM
TTLS1GP's Avatar
What ^^ said for cushy DD.
The only issue is that if you like to bang the gears, you are going to have issues with the rubber trans mount failing on you from time to time.
For my DD, it's Poly all-round and for my racer is solid engine poly trans. This combo is not a whole lot worse for vibes (if at all) than full poly.
Old Feb 25, 2011 | 08:24 AM
tails8's Avatar
Poly engine and trans here. No vibrations at any speed..
Tails
Old Feb 25, 2011 | 03:32 PM
Pocket's Avatar
Poly engine, rubber trans here too
