Fox Mustang Budget Swap/ Motor Mount Questions
The truck pan hangs down too low, it's the deepest by far and should be avoided in Mustang Swaps if you're going to use the car on the street IMO. Look of an `98-02 Fbody pan, Hummer H3, also known as a "Muscle car pan" or something from the aftermarket.
Well, I already have a 4.6 Kmember and A-arms. All I need is 4.6 mounts. I seen the thread where it shows you how to mod the mount to fit the iron block. Could I just use a 1/4 or 3/8" plate of steel and bolt the mounts to it and then to the engine? Has anyone done this instead of modding the mounts?
