ls3 injector pinout
Pink is 12V, the dark green/black is ground. The LQ4 harness the topmost wire looks to be a faded pink wire, so that's 12V and the white is ground.
What's the LQ4 harness off of? I looked at a couple LQ4 diagrams and can't see any with white ground wires for the injectors.
They should be numbered. Look at the top by the wires it should be numbered. I just bought the same connectors you did but have not started wiring yet. If need be I can run out the the garage and look at mine.
