LS1 camshaft in a 5.3 LM4
Old 03-07-2011, 10:23 PM
1970's Avatar
Default LS1 camshaft in a 5.3 LM4
Is it worth the effort?
Will performance change?
Will it need to be tuned different?
Old 03-07-2011, 10:32 PM
Rick Speed's Avatar
Not really worth the effort. You wont notice a differance and it'll run with no tune required.
Old 03-07-2011, 11:09 PM
itsslow98's Avatar
Id do an LS6 Ive heard they are great cams for these motors and even more so for boost.
Old 03-08-2011, 03:06 AM
71ANTICARB's Avatar
Might depend on which LS1 cam you choose, but I would definitely go atleast 02-04 ls6 if it was my and you would need atleast valve springs and probably a tune.
Stolen from LS1truck.com.
year/part number/Duration @ .050 lift int-exh/Valve lift int-exh/Lobe Centerline LSA
Corvette LS1
97-98 12554710 199/207 .472/.479 117
98-99 12560964 199/207 .472/.479 117
2000 12560968 198/209 .500/.500 115.5
01-03 12561721 198/207 .467/.479 116
Corvette LS6
2001 12560950 204/211 .525/.525 116 385hp
02-04 12565308 204/218 .555/.551 117.5 405hp
Camaro/Firebird
98 12557812 198/209 .500/.500 119.5
99-00 12560965 198/209 .500/.500 119.5
01-02 12561721 196/207 .467/.479 116
Trucks and SUV with Vortec engine
LR4 and LM7
99 12560966 191/190 .457/.466 115.5
00-04 12560967 191/190 .457/.466 114
the 03-04 LM7 used the 12560967 camshaft
LQ4
99-00 12560967 191/190 .457/.466 114
01-04 12561721 196/207 .467/.479 116
01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam
LQ9
02-03 12561721 196/207 .467/.470 116
Old 03-08-2011, 07:42 AM
1970's Avatar
Stock 2004 LM7 5.3
with LS1 intake, etc.
If I add a 2004 LS6 cam, springs, push rods available for $250
Question: Do I need a tune or can I upgrade to a better ECM?
Old 03-08-2011, 09:19 AM
71ANTICARB's Avatar
That's a pretty big change in the cam. I bet it would run but prolly would be down on power without a tune. I would think that you could tune the ecm you have.
Old 03-08-2011, 11:09 AM
1970's Avatar
Originally Posted by 1970
Stock 2004 LM7 5.3
The stock LM7 uses regular gas.
Will the cam upgraded LM7 require premium gas?
Old 03-08-2011, 11:58 AM
Pocket's Avatar
No
Octane requirement is based more on compression than valve timing
Old 03-08-2011, 03:40 PM
zipster's Avatar
Hey 1970,
I wanted a cam upgrade but am on a tight budget. So I had a cam reground by Delta camshafts. My cam is 224/230 @ .050 580 lift on a 112 c/l it was $112.50 including shipping to me. The I bought take off Z06 springs for $50.00. Would I like more cam, yes, but I want to get this car running soon.
Old 03-08-2011, 09:30 PM
Rick Speed's Avatar
You can run a LS6 cam with out a tune. A tune will give you another 30hp roughly.
Old 03-09-2011, 02:29 AM
71ANTICARB's Avatar
So without a tune it wouldn't be worth it.
Old 06-05-2013, 07:28 AM
Bankroll Bullies's Avatar
Where did you find stock ls6 cam and springs and push rods for $250? Thats what im looking for but cant find them for that price.
Old 06-05-2013, 09:28 AM
bczee's Avatar
You could have picked up a new set of LS6 springs from SDPC... for a few more $$'s (IIRC $54). For that pirce, why use Used one ??
You need to make sure the Push Rods are the correct lenght.. as the LS6 cam has a smaller Base Circle. Most usually go with longer 7.425", other have stated stock 7.4" will work.
You should be ok without a tune for the most part.. but one would be recommened.
BC
Old 06-07-2013, 02:33 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
GM actually installs the LS1 cam in their performance variant of the 5.3 engine. It's the LS327/327 which hints at the fact that they rate it at 327hp. So the gains really are not significant.
I ran the LS6 cam in my wife's 5.3 LS swapped 98 Silverado. It ran pretty good, but much better with a tune. I've recently swapped her to our 214/218 cam and it's quite a bit better than the LS6 cam was. Oddly, driving it feels like both cams have about the same sogginess in the bottom of the powerband (which isn't really that bad but is definitely present) but the 214/218 really comes in when you get the RPM up and the LS6 cam was fairly linear.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 06-18-2013, 09:20 AM
Ok, I just got an ls2 cam, ls2 push rods, and ls6 springs for cheap. What do I need to change on a LM4 or LQ9 to make them work? Im lost when it comes to cams but got a deal on the ls2 stuff and seen they are a good cam for a cheap swap.
Old 04-04-2020, 10:53 PM
Cameron Condy's Avatar
Bring up and old thread sorry!
New here and to the LS community, purchased a 78 C10 a 99 LM7 swap. It has th400 with very low stall, I have a higher stall converter for it. 12 bolt truck axle with 2.73 gears, that needs changing bad.
I found a 2000 LS1 Corvette cam and springs for $150. Since its the LM7 is a 99 with the small cam think this would be worth the purchase? I still use this as my daily summer vehicle and use it for truck duties. The intention is to eventually make it a weekend cruiser with 400hp.
I have been trying to find 99 LM7 advise with out much luck. I'm not a cam guru to understand the full meaning of cam specs, any advise would be appreciated.
Old 04-04-2020, 11:24 PM
Received 3,114 Likes on 2,429 Posts
That cam will give it a bit of a kick. You will be going from a 191/190 .457/.466 114 LSA to a 196/207 .467/.479 114 LSA. Can use the same springs, BUT I would put some new LS2/LS3 springs in because of the old one's age
Old 04-05-2020, 07:25 AM
Michael Yount's Avatar
https://www.hotrod.com/articles/ls-cam-test-comparison/
All the testing done on a 5.3L.....
The following users liked this post:
Cameron Condy (04-05-2020)
Old 04-05-2020, 11:57 AM
Originally Posted by Michael Yount
I realize this, I’m seeing a lot of people saying it’s not worth it on the LM7. Since I have the 99 variant with 270hp, I’m wondering if it’s worth it.
Old 04-05-2020, 11:59 AM
I’m not very rehearsed in cam specs, I can see that it’s better just not sure how much. He’s selling LS1 springs with it.
Quick Reply: LS1 camshaft in a 5.3 LM4
