Ground Issues???
Old Jun 6, 2011 | 11:02 AM
bczee's Avatar
Just add the grounds and be done with it. It is a cheap fix to do and will take the question out of this puzzle once and for good !...
else your problem will keep coming up as offen as this subject and question comes up on threads !
Old Jun 6, 2011 | 07:39 PM
Pop N Wood's Avatar
Originally Posted by psiconversion
Just an FYI, we have seen instances where a ground was needed from the passenger side of the engine (where battery was connected), to the driver's cylinder head (where harness was grounded). Grounding is key.
And if you had just run a ground wire to each component instead of trying to ground things through the motor then you would have avoided the problem in the first place. That must have been a bitch to figure out.
If 90% of eletrical problems are related to grounds, then doesn't it just make sense that eliminating grounds will get rid of 90% of electrical problems?
I have a single ground wire running from the battery to the firewall. Zero electrical issues.
I need another beer and for all these damn girl scouts to get out of my house.
