LSX In 91 C4 Corvette My Swap
#61
ive got a 91 vette and i want to do this so bad!!! what are you doin with the stock ecm? do you have to keep it to run the guage cluster and other stuff inside the car?
#62
I already took it out. The oil plugs right in. The Temp gauge will plug into one turned down to fit the LS heads. Another option is to buy the 98 LS1 that has another lead and connect it there. The voltage should work just fine. The speedo and Tach will hook up to the new VSS. Hopefully
#63
#64
Here is one guy who tapped it and used an old school sensor.
You could always put your two sensors ot the oil pressure sensor location like the factory L98 with a spliter.
#72
#73
i'm at a temp stop on my conversion also (lq4 and 4l65e in 90 vette had zf6 ) .went to start it and no fire.then wile trying to scan,i burned up my hptuner interface because i had a battery charger hooked up and it took 2 weeks to replace.now i'm out of town for 2 weeks.but i bought a second pcm and will try to start again on nov 4th.
#75
#77
Ok, back to work. It took me a a while but I finally got the converter I needed.
Its a CDS 3500 built for N0S. I don't know if I ever mentioned this before but the long term plan is to spray a 100-150 shot on track days. I'm off this week we have a few things planned but otherwise its vette week.
#78
After 2 days of working on it pretty much non stop I have learned two things. One, Putting in a transmission with out a rack and only 13" off the ground is very hard. Two, I'm not as young as I once was.
I got the trans mission in place and I'm headed back to modify the C-beam. Its off by about a half inch. Here are a couple of pictures of the trans and one of the C-beam holes.
#79
It's in!! Right now the Engine, transmission, C-beam, and rear end are mated and everything looks good. This for me is a mile stone. I need to install the drive shaft but I don't see this will be a problem at all. I only had to elongate the C-beam mounting holes .25 inches.
My goal for this week was to be at this point. This weekend I can finally start working on extending my wiring. I'll take some pictures Saturday we are out of town until then.
#80
Today I learned the C-beam and drive shaft have to be installed together.
I took the C-beam out to clean it up. I them put it back and could not install the drive shaft. So then I took the C-beam out and put in the drive shaft and could not install the C-beam. Finally i put the C-beam in place and moved it over until I had enough room to install the drive shaft then bolted the C-beam in place.
The exhaust lines up pretty good. It looks like the Left/drivers will need to be cut down a little. If I could get a hold off some 98 corvette exhaust the first couple of feet I will be in business.
The last picture is the cats I will be using. They will have to be cut down.
