pcm tuning
did you remove any of the smog equipement or is all the emission parts still there and connected ?
You can also get a mail tune with basic tune or minor tweeks.
p0443-evap emission purge control valve (2x)
p0449-evap emission vent valve malfunction (2x)
p0452-evap emission system pressure switch(low input) (2x)
p0135-o2 sensor heater circuit bank#1 sensor#1
p0141-o2 sensor heater circuit bank#1 sensor#2
p0155-o2 sensor heater circuit bank#2 sensor#1
p0161-o2 sensor heater circuit bank#2 sensor#2
Also do check for power to the O2 sensors. Are you sure you have the correct O2's for your wiring harness? There are 'case grounded' and 'PCM grounded' sensors, maybe they're not grounded?
p.s. ls1nova71 whats brewing in the garage? its summer and im waiting for another great build from, you.
I was getting some odd problems that started after the Thunderbird got wrecked. I discovered a ground wire and a relay had been damaged in the wreck. Once I fixed them the car drives like new - well newly swapped which is better than new.
As mentioned before, the EVAP and bank * sensor 2 codes should be simply disabled in whatever tune software. I know in HP Tuners it takes me longer to find the proper code(s) that it does to disable them.
