LS1 IN 69 Chevelle
Old Feb 21, 2004 | 09:43 AM
balls2thewall's Avatar
Question LS1 IN 69 Chevelle
I have a good line on getting a ls1 and a t56 trans for $5000 canadain. I was wondering what has to be changed to the car to fit. My dad did some reserch and he said that you have to change the cross member and a hole **** load of things i was wondering if any one has don this befor???? and what did they have to change to get it to work ???
JIM
( from the frozzen North )
Old Feb 21, 2004 | 11:15 AM
Grimes's Avatar
I think it's pretty much engine mounts and a crossmember. Then the hole for the shifter to pop through. you may need to watch out for some clearance issues with accessories, and suspension/steering, but it can be done.
Old Feb 21, 2004 | 02:26 PM
FAST LS1's Avatar
Go to the Hybrid forum. I think there are some people that have already swapped an LS1 into that body style.
Old Feb 21, 2004 | 05:14 PM
Steve1969LS1's Avatar
I think $7500 sounds like too much $$$ for the drivetrain.. is it brand new??? I paid $2800 for my 20k miles motor AND trans..
Old Feb 22, 2004 | 01:18 PM
bump plz
Old Feb 23, 2004 | 09:28 AM
how do u get $7500 when it would be more like $3500 amarican but now i have found out more about the ls1 swap i think im going to use a tpi motor with the t56 trany insted
Old Feb 23, 2004 | 10:16 AM
Ha!.. i did the math wrong.. Canadian $$ = LESS US $$.. not more.. in that case it seems like a decent price.. how many miles on the motor? has all the accessories?
Ive seen an install in a chevelle.. it was in a recent magazine but I cant seem to recall which one.
Old Feb 23, 2004 | 05:05 PM
i think it had 45k miles on it but im going to go with the tpi motor like i fist planed it looks meener and better toque range i laid the motor out in dest top dino and got this
rpm power torque vol eff%
2000 173 455 80.6
2500 219 460 82.8
3000 263 460 84.0
3500 305 458 85.9
4000 344 451 87.0
4500 371 432 86.2
5000 384 403 84.0
5500 380 363 80.3
6000 359 314 75.2
the set up is a tpi 350
Wedge/Pocket Porting, Stock Valve Size
10.0 to 1 compertion
Large-Tube Headers With Mufflers
104224 crane.cam
i just want it for a good every day hauler and some track
Old Feb 23, 2004 | 06:55 PM
Scooter70's Avatar
Those TPI motors definitely run out of steam after 5k.... I've logged quite a few laps at Watkins Glen in a '91 Corvette and running down the back stretch, the car was definitely running out of power before 5500rpm. I could only manage to top out at ~123mph where the LT1 and LS1 guys were getting closer to 140-150!! Down low they do make some nice torque though!! Coming out of the corners, I could pull on just about anything short of a 427 Cobra.
Just something to think about... my 2 cents.
-Matt
Old Feb 24, 2004 | 12:14 AM
ya but i live in canada there are no real race tracks around exp.. for mission race way. Mainly i want the car for an everday driver but i want to be able to go to the track and have a great time i want to be in the low 13 sec. Man its funny in Vancouver B.C. Richmond and vancouver is Import city the surrey is mustangers and the chilliwack is good old time old scholl v8's ferther you go away from the city the bigger the displacement. As soon as one type goes in to the others area they want to race. hopfuly they will see my car and think again. If you have any advice on building a tpi its going to be hooker up to a t56 and 4.11 or 4.56 rear gears and the car weighs about 3400-3600 lbs.thanx I was told by a few ppl that the numbers i got for the motor will never happen. And do you know what the stock cfm of the tpi and how much power that block can take ( witch tpi is the best year to get )
Old Feb 27, 2004 | 11:35 AM
Heretic's Avatar
The original TPI was designed around a 5.0 liter.
You will want to upgrade runners and base, port the plenum and get a 52mm TB.
I'd go with SLPs siamesed runners and get some top end back. 20" is a bit long for a runner.
You will be shifting like a semi driver with a TPIs torque band with a t56+4.56. I'd go with a 3.73.
Old Feb 27, 2004 | 12:58 PM
1963 SS LS1's Avatar
Smile
JIM
Take a look at www.hotrodlane.cc, they put an ls1 into a 70 chevelle and should be about the same.
Old Feb 27, 2004 | 03:26 PM
Yep.. here is a link to the exact article over there
http://www.hotrodlane.cc/70chevelle/1970ls1chevelle.htm
