What to use best?
Old Feb 22, 2004 | 08:35 AM
pjtimmer's Avatar
Default What to use best?
Hee guys,
Soon I am going to the weldingshop(machine fabricator) to have them make me a custom fueltank.
If I can choose, what should I choose for and why?
A full stainless tank with baffles
or a Aluminuim tank with baffles
Do you guys recommand no baffles but racing foam?
I will be using a 2000 LS1 fuel pump with regulator and sender.
Can I use a y-block mounted on the tank or on the body near the tank like stock? I would like to use a Y to put the feed on and the retrun and main feed. I would like to use AN hose and fittings which Y block should I take?
If I see a -AN8 Y-block could I use a reducer fitting to -AN6 for the retrun hose? second: or should I better use a -AN Tee fitting?
How to connect the hose to a 2001 fuel rail? what fitting or bung is needed?
I hope you can help me out guys, thanks
Peter from Holland
Old Feb 23, 2004 | 04:12 PM
pjtimmer's Avatar
any input guys?
thanks
Old Feb 24, 2004 | 08:39 AM
crainholio's Avatar
Baffles are a necessity if you corner. I have no experience with foam liners as a fuel motion control, so I can't say if it's better than baffles...but I know baffles work.
For a street car with no cage or safety liner for the fuel cell, I'd avoid aluminum. An accident impact will open an aluminum tank much more easily than steel.
I have no advice on the y-block question unfortunately. I mounted an Aeromotive regulator in my engine compartment, and reused my '82 Camaro feed and return steel lines.
Old Feb 24, 2004 | 04:57 PM
pjtimmer's Avatar
Thanks, so i should go with stainless steel?
About the Y-block, I am more thinking towards the Tee fitting, using the the straight for the feeds and the 90 degree one for the return with a reducing fitting, this should work right?
thanks
Old Feb 24, 2004 | 05:05 PM
xjarayax's Avatar
Why not just find a 99+ plastic tank?
Old Feb 24, 2004 | 05:10 PM
crainholio's Avatar
thanks
If the choices are stainless steel or aluminum, I'd go stainless steel. With baffles positioned correctly for your pickup. Make sure you bring them your in-tank pump and pickup assembly so they can locate the baffles in the right place to keep the gas in the right place...around your pump's filter-sock.
As for the T or Y block...where will the regulator be?
Old Feb 24, 2004 | 05:44 PM
pjtimmer's Avatar
Thanks, I will use the 2000 LS! fuel pump with internal regulator on the return end.
So instead of the stock block I will use a Tee fitting, should do the same isn't it?
thanks
Old Feb 25, 2004 | 08:57 PM
67ls1CamaroProject's Avatar
thanks
Glad to see you received the fuel pump.
For the fuel rail, I used some Russell Hard line to AN adapters. Jegs and Summit sell them for like $7. They clamp down on the fuel rail and leave you with either a female or male AN fitting to hook up to. Works great and is easier than flaring or brazing.
