What kind of gauges are you guys using
Old May 2, 2011 | 08:33 PM
grafking's Avatar
Default What kind of gauges are you guys using
What kind of gauges are you guys using with your conversion. Do you have pics.. How did you set everything up?... I am using the stock Camaro gauge cluster...
Old May 3, 2011 | 12:19 AM
theomms's Avatar
I would like to know this too.
I have seen some cheap Dolphin brand gauges on ebay, but it seems too good to be true when the autometer and classic gauges are twice the price.
Also, has anyone use speedhut.com gauges?
Old May 3, 2011 | 12:23 AM
eroc022's Avatar
im running or going to be running all the factory gauges in my t/a. speedhuts got some good stuff ive seen some posts here and there everyone is happy with them.....
Old May 3, 2011 | 12:27 AM
G-Body's Avatar
sawzall wielding director
Factory gauges, with autometer speedo guts stuffed behind my factory speedo face.
Old May 3, 2011 | 12:34 AM
wtf.suv's Avatar
I recently ordered gauges from speedhut, great place to deal with, and the gauges are way nicer then the autometer gauges i have for my truck... would recommend them for sure
Old May 3, 2011 | 12:50 AM
1981TA's Avatar
I'm running VDO gauges in my 1981 TA. They look and work great, but are pricey. $600 for tach, speedo, water temp, oil temp, oil pressure, voltage and fuel level + all the sending units. Got the whole set up from eGauges.com (awesome customer service, btw).
Old May 3, 2011 | 12:55 AM
01cherryreds10's Avatar
Dakota Digital for the Malibu/Monte Carlo. I'll put a picture up tomorrow, it's not in the dash or wired, but I have it mocked up inside the gauge surround.
Old May 3, 2011 | 03:08 AM
Rare96WS6's Avatar
I used the stock guage cluster that is in front of the steering wheel in my 1968 Camaro. The 5" electronic Autometer Antique beige guages fit perfect. I also put the other 4 guages on the center console where the stock square ones went. There are pics of them in my garage on this site. I hooked everything up electronically since the engine already has all the sensors on it. I wanted the conversion to look as close to stock as possible.
Old May 3, 2011 | 07:37 AM
Pocket's Avatar
Stock 92 Firebird gauges. Whole cluster works just like it did back in 1992
Added ebay glowshift boost/fuel pressure gauges with the blower. They're accurate enough to justify using
Old May 3, 2011 | 07:39 AM
46Coupe's Avatar
I am using Classic Instruments gauges.
I have not had an opportunity to test them out yet, but I don't foresee any issues using them.
Old May 3, 2011 | 08:58 AM
1A Dan's Avatar
stock 94-95 TA guages; upgraded my dash when I upgraded my motor
Old May 3, 2011 | 01:17 PM
LSCha0s's Avatar
Pocket, I'm doing a 91 corvette swap. Our gauges should be similar. Did you have to use any converters?
Old May 3, 2011 | 03:55 PM
Pocket's Avatar
No, just connect the proper wires and it works. Had to run a booster wire for the tach, but otherwise 1:1 connection
Old May 3, 2011 | 06:19 PM
LSCha0s's Avatar
That is great news
Old May 4, 2011 | 03:21 PM
Clyde65's Avatar
I have Dolphin gauges except the temp guage, that is autometer, Dolphin said theirs wouldnt work with the autometer sender I put in the pass head. They work great, great price. I did have to hook up my speedo to the wire off the trans though, not the supplied one from the PCM
Old May 4, 2011 | 03:39 PM
speedtigger's Avatar
Old School Heavy
I was going to build a custom instrument panel with aftermarket gauges but my daughter objected saying it would destroy the natural character of the car. So here is my compromise:
Attached Thumbnails What kind of gauges are you guys using-dash-small2.jpg   What kind of gauges are you guys using-dash-small3.jpg
