My roll racer 86 coupe,LME LSX 440,Twin billet 71's and a t56 magnum
Old 05-18-2011, 02:26 PM
  #41
Clean94Z's Avatar
Originally Posted by General_Joser
damn this is a great build, what size tire are you planning on using?
Low boost settings will be on M&H 325/45R17 DR's. High Boost will be MT 325/50R15 DR's
Old 05-18-2011, 04:45 PM
  #42
dmracing's Avatar
Can you post pics of the trans crossmember? Did you have to switch it around, since you flipped the motor mounts?
Old 05-18-2011, 05:50 PM
  #43
General_Joser's Avatar
nice those are some nice size tires, did you have to shorten the rear end at all?
Old 05-18-2011, 09:08 PM
  #44
Shon Herron's Avatar
more info on the T56 install, ie what parts did you use, other than an Fbody trans and shifter, what pedals, M/C, etc??
thanks!
Old 05-19-2011, 12:11 PM
  #45
Clean94Z's Avatar
Not with the mini tub. I had the fenders rolled and will use a 6.5 backspacing on a 15x10 for the 325/50R15. Look something like this
thanks!
T56 magnum for gm with the 2.66 gear set
quicktime bellhousing
mcleod rxt twin disc with miba disc
ram slave cylinder
aje t56 crossmember
the pedals I have right now are the standard t5 pedals. I have a friend that built a bracket on his and it works great. We have not done mine yet because the car is not that far along. But soon!!
The master cylinder is wilwood. If you want part numbers I can get them when I get to the house. I found them on here when someone did the swap.
I think thats it..
Old 05-19-2011, 12:42 PM
  #46
thats a tight fit it won't rub?
Old 05-19-2011, 02:08 PM
  #47
Clean94Z's Avatar
Thats the setup that car has and he has no issues. Every car is different though. Mat require alittle work. That car by the way is owned by BRENT DAVIS on the turbomustangs.com forum. Dynoed 1177whp and ran a 10.0@170 with a tko600 lol!! sickness
  #48
Clean94Z's Avatar
Been working on interior stuff!! trying to knock out the things I cant to make it go together quicker when she gets back. My wife bought me brand new upholstery for my factor seats!! So I stripped the seats down and started recovering them. Thank god my boys in the shop have kickass hog ring tools!! I had to order another driver seat low frame and seat brackets. I guess this car had the typical mustang gangsta lean and someone tried to fix it. Did a crap job. Anywa here are before and after pics
Old 05-19-2011, 02:36 PM
  #49
**** thats sweet! those seats are looking great
Old 05-19-2011, 03:34 PM
  #50
Clean94Z's Avatar
Alot of people pushed me to do racing seats but I want the stockish look inside the car. And I want to be comfortable. I can give up a few pounds for that.
Old 05-19-2011, 03:44 PM
  #51
i hear ya, was it hard to remove the whole dash out of the car to paint?
Old 05-19-2011, 03:48 PM
  #52
Clean94Z's Avatar
The 86 dash was a motherfxcker to get out!! Only because there was one bolt that was on top of the steering column that I could not get to. The stock 86 dash I broke to get out because I had a grey one for it. That I still have actually. I trimmed out the area for the gauges.
But then I decided I wanted the 87-93 dash because I like the console setup better. So thats what I have now.
Old 05-19-2011, 04:41 PM
  #53
sounds good thanks man this is good to know, i remember i took off a 98 camaro's dash and it was a puta as well
Old 05-19-2011, 09:16 PM
  #54
N20neenee's Avatar
I would love to see a picture of that clutch bracket whenever you get around to it
thanks
Sean
Old 05-20-2011, 08:58 AM
  #55
Clean94Z's Avatar
thanks
Sean
Will do!!
Old 05-23-2011, 04:07 PM
  #56
Clean94Z's Avatar
intercooler teaser
Old 05-23-2011, 04:11 PM
  #57
damn thats a big sucker!
Old 05-24-2011, 12:32 AM
  #58
LS1PUNK's Avatar
ANy more pics?
Hard to tell how ur gunna run the cold side from the inter-cooler to the TB.
Old 05-24-2011, 10:46 AM
  #59
Clean94Z's Avatar
1500hp air to air baby!! flow 2238cfm, 3 cores good for 497hp ea and the best part!!! parts were just shy of $500.00
Originally Posted by LS1PUNK
ANy more pics?
He is still working on that.
This is the teaser he sent me
Old 05-24-2011, 11:22 AM
  #60
FakeSnake's Avatar
where did you get the intercooler cores from?
Quick Reply: My roll racer 86 coupe,LME LSX 440,Twin billet 71's and a t56 magnum
