5.3/T56 swap into a First Gen RX7 GS **Update 3-25-12**
I am moving my build post to here instead of Introductions. ( old post)
Quick review I had a chance to pick up a 2000 5.3L LM7 with harness for $150 so the project just steam rolled from there to trailoring my Project RX7 from my parents farm to Moorhead so I can work on it all the time. I have been doing a bunch of research on this project and sadly there is not much specific info on swapping a Gen III SBC into a First gen RX7 SA or FB. So I am taking info for basic LS swaps and older SBC swaps and RX7 purist pages as well. By purist I mean the types that would gut me and stick my head on a spike for doing this, lol. I had plans of running a newer 13b S5 N/A engine in this car but lost interest a while ago. We all know that V8 power is so much more fun!
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/s720x720/556389_10151822403120494_1448749877_n.jpg)
The run down so far:
Drivetrain
5.3L LM7 from '00 Silverado with 60K Toasted #8 rod bearing journal, looks like debris was the cause
T56 from '02 Firebird with 124K
Ford Explorer 8.8 3.73 with Trac Lok
Hooker LS to SBC adapter plates
Solid Engine mounts Trans-Dapt Polyurethane Engine mounts
Modified Truck pan
Modified Truck Harness
LS1 Harmonic Balancer
Truck Alternator with custom low mount
Stock Subfame with added steel and V8 mount brackets welded on
Custom Transmission Crossmemeber
Cooling
Jegs universal Radiator 24x19 #555-52006
Hayden 16" electric fan, no shroud
New LS1 Water pump
Stock Thermostat
Fan programmed for 195* turn-on
Air/fuel
Walboro 190 inline pump (upgrading to 255)
Specter 4" cone filter
MAF delete
Truck Intake
Exhaust
Headman Block hugger LS headers (looking for better fit)
LS3 Camaro Exhaust Manifolds! Perfect FIT!
2.5" Stainless duals to Magnaflow Mufflers and turn downs
LS1 Intake Manifold is in the works
And a few pics...
![](http://i784.photobucket.com/albums/yy122/SS-Jon/RX7/IMG_20110523_093052-1.jpg)
![Name: IMG_20110523_093241-1.jpg
Size: 82.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616371d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110523_093241-1.jpg)
First time setting the V8 in there
![Name: IMG_20110523_185659.jpg
Size: 118.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616372d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110523_185659.jpg)
![Name: IMG_20110523_185739.jpg
Size: 138.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616373d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110523_185739.jpg)
![Name: IMG_20110523_185716.jpg
Size: 127.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616374d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110523_185716.jpg)
![Name: IMG_20110523_185747.jpg
Size: 113.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616375d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110523_185747.jpg)
Looks like I need a LS1 or LS6 intake
![Name: IMG_20110525_211709.jpg
Size: 158.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616376d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110525_211709.jpg)
![Name: IMG_20110525_211730.jpg
Size: 97.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616377d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110525_211730.jpg)
I had the Truck oil pan cut down, removed 3" from the bottom of it for some needed ground clearance. I cut and shorted the Stock pick-up tube to go with. Installed stock RX7 oil cooler, picked up some Dorman Oil cooler lines and spliced hoses together.
![Name: IMAG0058.jpg
Size: 60.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616378d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0058.jpg)
![Name: IMAG0057.jpg
Size: 68.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616379d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0057.jpg)
![Name: IMAG0059.jpg
Size: 52.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616380d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0059.jpg)
![Name: IMG_20110531_161931.jpg
Size: 78.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616381d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110531_161931.jpg)
![Name: IMG_20110531_161957.jpg
Size: 96.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616382d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110531_161957.jpg)
![Name: IMG_20110603_203223.jpg
Size: 116.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616383d1501349272-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-img_20110603_203223.jpg)
Next up is fabbing some engine mounts as soon as my T56 shows up. Plus tons more after that so check back for progress.
Drivetrain
Modified Truck pan
Cooling
New LS1 Water pump
Stock Thermostat
Air/fuel
MAF delete
Truck Intake
Exhaust
And a few pics...
How will you drain the oil when it comes time for an oil change? Wonder how many quarts that thing will hold. I cut mine about 1.5" and I wanna say it holds around 5 1/2 quarts or so. I bet the filter will still hang down beyond the bottom of the pan. Welds look good.
Ok, I have been killing time waiting for my transmission to show up. It was supposed to be here Monday but the shipping company blames engine failure and what not so tomorrow looks to be the day. I took the engine to a machine shop to have a broken off exhaust bolt removed, rear one on the left bank, seems pretty common. Bolted up both Headman Block Hugger headers, not happy with the crappy paint job on them. It will all burn off eventually and I will wrap them or have them ceramic coated eventually. Oil pan is bolted up, clears modified oil pick-up by almost 1/2", is this enough? I never measured stock clearance. I also made sure to line up the back of the pan with the bell housing using a straight edge.
![Name: IMAG0076.jpg
Size: 134.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616357d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0076.jpg)
![Name: IMAG0077.jpg
Size: 100.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616358d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0077.jpg)
![Name: IMAG0075.jpg
Size: 112.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616359d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0075.jpg)
![Name: IMAG0073.jpg
Size: 128.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616360d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0073.jpg)
![Name: IMAG0074.jpg
Size: 106.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616361d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0074.jpg)
And I rolled it out of the garage to pressure wash the engine bay, plus gave the rest of the car a quick wash.
![Name: IMAG0082.jpg
Size: 84.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616362d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0082.jpg)
![Name: IMAG0079.jpg
Size: 109.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616363d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0079.jpg)
![Name: IMAG0080.jpg
Size: 76.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616364d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0080.jpg)
![Name: IMAG0081.jpg
Size: 83.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616365d1501349219-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0081.jpg)
It sucks the the trim is falling off, I will replace it eventually, along with all door moldings and weatherstripping.
The beast finally showed up haha
![Name: IMAG0086.jpg
Size: 114.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616336d1501349184-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0086.jpg)
Everything going in for the first time, kinda tricky to do all by myself.
![Name: IMAG0087.jpg
Size: 92.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616337d1501349184-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0087.jpg)
I had it almost all the way in then I had to pull it back out to clearance the tunnel.
![Name: IMAG0084.jpg
Size: 112.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616338d1501349184-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0084.jpg)
Almost got it all cut off, ran out of cut off wheels for the 4" grinder. That thing eats them like warm chocolate chip cookies!
![Name: IMAG0089.jpg
Size: 100.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616339d1501349184-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0089.jpg)
TTLS1GP : thanks I will look into that.
blkjck: thanks I am loving this project and trying to do as clean and nice install as I can.
rockoosi1: I believe that with the added cooler and lines it will be at least a 5 qt system, should be good
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Progress has been slow, but there has been some. I have clearanced the tunnel for the beefy trans and welded some plates to the stock lower sub-frame to build engine mounts from. The left header is tight but clears the steering gear box by 1/8" and will be ok with solid mounts.
Left mount bracket
![Name: IMAG0004.jpg
Size: 87.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616310d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0004.jpg)
Right mount bracket is not complete yet, still some extra bracing to weld in
![Name: IMAG0005.jpg
Size: 71.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616311d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0005.jpg)
Header clearance
![Name: IMAG0003.jpg
Size: 71.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616312d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0003.jpg)
Yep it's that tight to the firewall
![Name: IMAG0008.jpg
Size: 60.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616313d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0008.jpg)
![Name: IMAG0009.jpg
Size: 102.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616314d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0009.jpg)
![Name: IMAG0010.jpg
Size: 106.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616315d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0010.jpg)
Steering Center link need some modification, it hits the oil pan right before the lock on each side
![Name: IMAG0017.jpg
Size: 42.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616316d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0017.jpg)
Bottom side clearance
![Name: IMAG0018.jpg
Size: 76.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616317d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0018.jpg)
Not sure what happened to the tailshaft, it was all chewed up like that when I got it from the Junk-yard.
![Name: IMAG0015.jpg
Size: 89.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616318d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0015.jpg)
Shifter hole had to get cut open 3" back
Left mount bracket
Header clearance
![Name: IMAG0011.jpg
Size: 72.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616319d1501349135-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0011.jpg)
You got it
I have made pretty good progress since last update. Fuel pump and filter are plumed in, same location as stock electric pump and filter. I am running the stock 3/8" steel lines, and stock return line. Fuel pump is a Walboro 195lph.
![Name: IMAG0031-1.jpg
Size: 81.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616043d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0031-1.jpg)
I finished the subframe with solid engine mount brackets welded on.
![Name: IMAG0019.jpg
Size: 55.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616044d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0019.jpg)
![Name: IMAG0021.jpg
Size: 67.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616045d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0021.jpg)
![Name: IMAG0026-1.jpg
Size: 93.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616046d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0026-1.jpg)
Transmission subframe is also fabbed up from raw materials.
![Name: IMAG0112.jpg
Size: 80.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616047d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0112.jpg)
![Name: IMAG0110.jpg
Size: 72.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616048d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0110.jpg)
![Name: IMAG0107.jpg
Size: 66.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616049d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0107.jpg)
![Name: IMAG0114.jpg
Size: 70.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616050d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0114.jpg)
I installed the new Clutch Master cylinder, just needed to cut the hole from 1" out to 1 3/8" God Bless Harbor freight for having a step drill bit the perfect size for only $12
new and old
![Name: IMAG0001-1.jpg
Size: 41.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616051d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0001-1.jpg)
![Name: IMAG0143.jpg
Size: 63.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616052d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0143.jpg)
And here is sits, engine installed with truck intake and accessories.
![Name: IMAG0132-1.jpg
Size: 106.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616053d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0132-1.jpg)
![Name: IMAG0129-2.jpg
Size: 103.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616054d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0129-2.jpg)
![Name: IMAG0128-1.jpg
Size: 113.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616055d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0128-1.jpg)
![Name: IMAG0131-1.jpg
Size: 90.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616056d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0131-1.jpg)
![Name: IMAG0130-1.jpg
Size: 81.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616057d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0130-1.jpg)
Truck accessories with custom Alt mount and idler.
![Name: IMAG0142.jpg
Size: 73.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616058d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0142.jpg)
Fits the firewall really tight, I had to unbolt the hood latch. Good thing the truck intake, water pump, crank pulley are only temporary.
![Name: IMAG0127.jpg
Size: 71.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/616059d1501348547-5-3-t56-swap-into-first-gen-rx7-gs-update-3-25-12-imag0127.jpg)
Another note, my block hugger headers are not a great fit with my whole steering system! I am planning on changing out to the Clipster headers.
http://www.speedwaymotors.com/1955-5...ers,14264.html
I will order them up when enough funds come my way. Right now to drive the car I need a fusebox, PCM tune, driveshaft, starter, battery.
new and old
