408 LQ4 with LS3 Top End... Water Pump HELP
Did you try an L92 truck pump with the angled outlet or the original LQ4 with the vertical outlet?
Options:
You can get 3/4" spacers off ebay and run an f body pump.
Pull the f body pulley forward on the shaft.
Use an L99 water pump
Swap the truck pulley onto the f body pump (I did that one)
Buy one already swapped.
http://www.foxlinders.com/accessories/waterpump.html
Options:
If you are sticking with the DBW throttle body you can flip it 180* so that the plug connector and little motor are on the driver side, basically it will be upside down but it will still function fine.
You got a couple options. Obviously the truck pump will not work. If you want to run the LS1 pump you can, but you either need to run other ls1 accessories (including balancer), or you can run the LS1 pump with truck accessories and the spacers from ebay, which are about $75.
I went the spacers. I wish now that I wouldn't have. If I were you I'd do the ls1 kwik brackets, ls1 pump, and ls1 balancer.
