LTX --> LSX Conversion Sticky
Old Mar 2, 2023 | 05:34 PM
  #221
the_merv's Avatar
Originally Posted by Chased
I'm going 408 in my 96 TA this thread is awesome.
BUT that wiring harness looks like it's going to have me going crazy
Wiring is pretty easy..
Yes I know this is from about 5 years ago. I haven't been in this thread in a LOONGGG time... just going through it and putting it up to the top.
Old Mar 3, 2023 | 10:33 AM
  #222
More like 6 years.... but who's counting?? LOL
Old Mar 3, 2023 | 07:25 PM
  #223
the_merv's Avatar
Apparently not me, ran out of fingers on that hand..
Old Mar 20, 2023 | 01:55 PM
  #224
gjohnsonws6's Avatar
I am currently doing my 96 T56 and might be making a post soon once I determine exactly what is going on and can ask better questions. 96 C220 connector layout is different and I’m not finding too much on it. Checking for CPP, Ignition 3, and Neutral safety at the moment. I also might have the tach wrong with the 93-95 Pinouts compared to 96.
Edit 3-21-2023: Tach is correct as listed, Ignition 3 and B/U lights connected.
Old Mar 20, 2023 | 05:27 PM
  #225
the_merv's Avatar
I put this together with added notes a long time ago, spot on. C230 H & J are the Brown and Lt. Green if the car is a Manual.
Old Mar 20, 2023 | 11:35 PM
  #226
Thanks merv, I’m now down to this last one:
- Blue PCM Pin 32 Gray CPP, C220 Pin B (LS)
Then making everything final at the fender and I’ll be set.
EDIT: possibly found gray clutch anticipate on C230 A (LT dash side) Which is the 5 volt reference on the LS C230 pin A engine side.
Old Mar 21, 2023 | 06:53 PM
  #227
the_merv's Avatar
C230A, as per my diagram, is basically a light on the dash that says Sport Mode. I've never wired the Clutch Anticipation Circuit or switch and have never had any issues.
Old Mar 21, 2023 | 09:46 PM
  #228
This is where I found it, I’ll trace it out soon and report back with my findings. I’d like if it was hooked up but understand that it will work without as well. If this is the case then I’ll be wondering about the 5 volt next. Hopefully this all works and will be a good contribution to the thread.
https://www.camaroz28.com/forums/lt1...s-help-873857/
My C230 dash side:
Old Mar 22, 2023 | 07:36 PM
  #229
the_merv's Avatar
Per that link, it says that is for a V6 car..
1996-1997
Cavity Wire Color Description
A Grey (Manual) Clutch anticipate signal
(V6 VIN S only-1996, VIN K only-1997)
Old Mar 25, 2023 | 10:34 PM
  #230
1996-1997
This one is in my dash harness at the pedal but not hooked up and indeed runs to C230 Pin A when ohmed out. There are 2 and 4 wire clutch switches, mine is equipped with the two pin. I’m going to install a 4 pin and route through A on both C230 connectors to LS PCM Blue connector pin 32 CPP for correct operation. I know people say it can get dismissed and I understand that but I also found info regarding drivability issues so I’m hooking it up anyways. I hope this helps anyone looking to complete this circuit on a 96.
Old Mar 26, 2023 | 02:38 AM
  #231
@the_merv Any ideas on this one? I put blue LS PCM connector pin 58 green to C230 pin C (LT dash). However purple serial data on K at 230 on LT side is there as well, this is a little confusing and also found this in my search.
Edit: Moved pin 58 green to pin K purple at C230 dash side = pin 2 at OBD 2 diagnostic plug
https://ls1tech.com/forums/lt1-lt4-m...-question.html
Old Apr 6, 2023 | 08:20 PM
  #232
the_merv's Avatar
I don't know why I ever posted a pic of that paper up above I annotated over the last 17 years that clearly states some of this stuff you are finding in your "searches"...
Old Apr 8, 2023 | 05:54 PM
  #233
Thanks for the help, everything is wired up and I’m hoping to get it started soon.
