LS into 190e 16v
Labeling all the pcm wires
Pile of stuff I pulled out
after pulling out all the unnecessary stuff
I ordered a relay and fuse box which should be here on monday. Once I get that in, I can splice the 190e and ls1 harness together.
I also bought this fuse/relay box from Current Performance Racing. It was $95 and comes with AC relay, Fuel pump relay, Ignition Relay (switched 12v power), Starter relay(which I won't be using), and fan relays. It also has fuses for the LS1 Pcm, fans, ac, coil packs, etc. It also comes with labeled pigtails and a really nice wiring diagram and pin out explanation. It's a pretty nice nice and I am very pleased with it. This is definitely a must buy if you want to do this swap.
I will hopefully be looming the harness over the next couple of days before I go home for the holidays.
http://www.mouser.com/ProductDetail/...osKRjZKlY60%3d
These are very small and will keep it all together.
After getting the engine in the car, I realized that I can probably get away with reusing the stock motor mount and making a mount that just bolts to the top of it. I figure if the turbo guys can make about the same amount of power that I will be making on the stock mounts then I should be fine. Plus the motors weight about the same, so I am not too worried about it. Plus, if all else fails, I will just buy a poly mount and call it good.
Here is the LS in the bay.
The GTO oil pan barely hit on the subframe. So, to make it clear, I cut the pinch weld off of the subframe and I put about a 1" by 1" notch in the pan.
Modified subframe (I will go back and clean it up and paint it once everything gets finalized.):
Modified Oil Pan (don't make fun of my welds. I am still learning.)
How the pan clears with the modified pan and subframe:
I also did some measuring and figured out that the shifter hole is ~32" from the back of the engine. Turns our a GTO shifter sits ~32" from the front of a T-56. I will be buying a stock GTO shifter over Christmas break.
Here is a pic of the modified engine mount:
Passenger side:
This mount will see the most force since the motor rotates clockwise when looking from the front of the car. This is with 900lbs of force acting on the mount face. This simulates half of the motor weight (~600lbs) plus the full force of the torque (~350 ft-lbs @ 7.5") on the mount. As you can see it shows a min factor of safety of .45. This occurred on a sharp corner of one of the tabs. This is a false reading of the software. There was a FOS of ~1 right next to the upper left hand mount hole. I will be re-enforcing this area with extra welds and possibly more material. Every where else showed a FOS of over 5. Therefore I am not too worried about these mounts failing.
Drivers side:
This mount was subjected to the same forces. This mount saw a min FOS ~1.8 that wasn't caused by a sharp corner (stress concentration) with most of the mount seeing a FOS >5. Again the area around the upper right and mounting hole will be re-enforced with extra welding and possibly more material.
I sent in the drawings today to have them water jet cut. I should have them by Wednesday. I should have the motor in the car by the end of the weekend.
and here it is all bent up. I will weld this one up today along with the passenger side mount. I hope to drop the motor in the car tonight. The low tonight is 30, so my garage is will cold as ****, but I think it will be worth bearing the cold to see the motor in the car for the first time.
Once I have the motor in the car, I will be able to finish all the wiring with the correct lengths and everything. After that is done, I will need to figure out a steering solution. I am still trying to find a good source for information about the dos and don'ts of modifying a steering system. I know how to calculate all the steering angles and everything, I just want to know if there is anything that I need to avoid/watch out for. Let me know if anyone has any good places to look for that kind of information. Thanks
I got the mounts welded up today. I decided just throw them together real quick and use them to help me mock everything up, so don't give me too much **** about the shitty welds. I know they are garbage. I have already decided to cut another set of mounts cut, so no reason to make those look really nice. Here are some pics
And on the motor.
And finally in the car.
After setting the motor in the car, I realized that the stock bushings are way too soft. I think that I will end up buying some poly mounts from Ake.
J/K Honestly they actually aren't terrible. I have seen people calling themselves fabricators and selling their work who can't do as well. You will improve with time because nothing teaches like experience. I like what you have done on the engine mounts, that is a pretty clean idea. I think you will be much happier with poly engine mounts too.
Not much of an update, but I got all the loom wrap and heat shrink for my harness.
Only cost about $80. I used buyheatshrink.com for the adhesive lined shrink wrap and cabletiesandmore.com for the loom wrap. We are supposed to get 6" of snow this weekend and have temps around 0°, but I still hope to get some of the harness done. I will probably be investing in a space heater.
I also got my valve covers and front and rear covers off my motor back from the powder coater. They came out really nice. I had them done in wrinkle black. I will post a picture tomorrow. I also will have the oil pan, water pump, and possibly the alternator coated as well. Should look pretty nice.
I have been working on the harness a little bit for the past couple nights. It is taking a but longer than I thought, but I'm taking my time and making sure I do everything right. Here is a picture of what all the connectors will look like when I am done.
Here are the two ECU connectors. I'm not finished cleaning up this end of the harness. The large grey connector to the left is a GM connector I stole off the body harness I had. It will go to the fuse and relay box I bought.
I still need to figure out the lengths of a couple of wires like the tach signal, switched power, O2 sensor, and a few other things, and then I can finish up this end of the harness.
I will work on mounting the ECU and fuse and relay box this weekend.
