LS into 190e 16v
This side gets bolted to the knuckle
My girlfriend got into school in Atlanta, and I wanted to move closer to friends and family, so we decided to move to Atlanta at the end if July. Now I get to go all the Tech games again, which means I probably work on the car as much as I should. I moved the car to a friend's shop in Nashville, TN. I used to work there in high school. Even though the car is now 3 hours away, it's nice having it somewhere where I can have a shop to myself for an entire weekend. I can go there to get away from everything and put in some quality time. I was able to head up there this past weekend and start working on my headers. I got the passenger side all tacted up. It went fairly smoothly. In debating paying someone to final weld it, so I don't **** it up. Haha. I'm dreading doing the driver's side. It's so much tighter with the footwell being farther forward and the steering column being in the way. I may have to move the steering column to get the headers to fit. And before anyone asks, the runners are 1-3/4" and I bought the collectors from Vibrant.
How I positioned the collector
Closer
Finished
I'm going back to Nashville again in two weeks to work on the driver's side. I need to buy some tighter radius bends for that side. I'll probably get some Columbia River bends. I used all vibrant bends for the driver's side. I hope I can easily move the steering column and make everything work. It should be a cluster ****, but oh well, this whole build has been one. Haha
As always feel free to ask any questions you might have.
Thanks
Clayton
Runners welded
Welding to the collector. I backed purged everything as well as I could
Not the prettiest welds, but they will do
Making sure nothing moved
Finished
And a final test fit. I can install it with the motor bolted up. I can also get to all the spark plugs, so that's cool
3 runners done. I also replaced my old steering column brace with a new one. I bought a bung and a heim from QS components and tacted it in place.
4th runner done. This one isn't quite as nice as the passenger side, but I am still pleased with it with the tight space I was working with.
You can see in this picture on the left hand side, to the left of the bottom left runner, I had to cut a large piece of the rear a-arm mounting feature off. This was where the drag link in the old steering system mounted. I will cover this with a piece of sheet metal next time the motor comes out. There is a piece of cardboard in the hole so I knew how much room I had.
Looking back at the firewall. I have at least .125" of clearance between the header and the steering column. the .125" clearance is right next to engine mount where engine movement should be minimal.
Header installed.
Under the car. The passenger head sits further back in the engine bay b/c the floorboard is pushed back farther on the passenger side to clear the stock exhaust.
Under the car looking towards the front. I should be able to put either v-bands or 3 bolt flanges on the collectors and then go right into a 45° bend and then back into the trans tunnel. I will probably run dual 2.5" tubes back into a 2 into 1 muffler and then 3.5" back to a single hidden tip on the driver's side. it's not ideal, but it will make more enough power, and I really don't have room for anything else.
I got to swing by my buddies shop while I was home. I saw something that you don't see everyday.
Pretty cool. Basically a race with street tires on it.
http://www.youtube.com/watch?v=wekbxaQXz50 I should be going next weekend to finish welding up the header. I will have more pictures then.
I won't have a chance to work on the car for the next couple of weeks. I hope to have much of the exhaust ordered by the end of the month and to start fabbing it in early November.
Clayton
Clayton
Anyways, also since my last post I bought another car. Oops. Also need to stop doing that. I sold the CTS-V and bought a 1994 540it/6. It's a swapped car that started as a 530it-auto, but now has a 4.0l m60 and a 6 speed.
I got into the shop last night and got my ECU mounted. I used a mount from Binks Fabrication (http://www.pirate4x4.com/forum/misce...ecu-mount.html). It's a pretty nice piece.
ECU Installed
I mounted the ECU in the factory location.
I drilled two holes in the mount and in the firewall. I will rivet the mount to the firewall after I get the mount powdercoated.
I also rotated the battery try to allow room for the fuse box. Everything should drop in pretty nicely.
I will need to spend some time this weekend doing some metal work on the battery tray to get it finished. I also need to make up a mounting block for the fuse box that will get riveted to the battery compartment floor. I hope to have more updates after this weekend.
I used a template to get the shape right
Transferred to metal
Tacked
Test Fit
Fully Welded
Battery and fuse box installed
Installed in the car
I also figured out where I am going to place to O2 sensor bungs and wired in the O2 sensor connectors. I drilled a hole in the battery compartment to pass the wiring harness through, and I ordered up the last fuel system components this week. Getting closer.
Pump to fuel rail
Tank to pump. I need to get a 12mm banjo to -6an male fitting. As you can see, I've removed the stock filter and accumulator. I'll run the factory fuel pump banjo bolt to maintain the check valve in the bolt. For the return I'll run a -6 line back to the tank. Got to go to the junkyard tomorrow to find a fuel line to steal the fitting so I can finish the fuel system in the engine bay.
I might actually be able to fire this thing up pretty soon.
Factory Mercedes hard line to fuel rail.
Return
I decided to get rid of the stock Mercedes fuel line fittings and go with -6 an tube nuts for the soft line to factory hard line connection points on the feed side of the fuel system. I ordered them from Summit, but bc of the snow in ATL they won't be here until after this weekend. I was hoping to do a test fire this weekend, but it doesn't look like that will happen. Oh well, I should be able to get some more work done this weekend. I figured out all the starter and oil pressure wiring. I also made an adapter from the LS1 oil pressure sender to run the Mercedes oil pressure sensor in the factory GM location. Hopefully I will have more updates after this weekend.
I got the fuel lines done. I painted the factory hard line. All I have left to do is seal off the factory line that came off the pump feed and went to the accumulator.
Here are some shots of the starter wiring. I connected all the wiring and actually heard the starter turn over for the first time in over 3 years tonight. Pretty awesome. I already ordered some heat sleaving that I will be using on this wiring. I also plan on making a small heat shield.
I also got my O2 bungs tacted in. Confirmed that you can uninstall the sensor with the headers in the car.
Up next is modifying the Columbia river V-Band flanges I bought. They didn't come with an alignment ring, so I am going to try and machine one in. We will see how that goes.
I hope to have some more updates after the weekend.
When I first went to flash the pcm I hooked the battery charger up to the car and accidentally put it on the 40amp setting. I had the pcm power fused with a 10amp fuse. The fuse blew immediately. I wonder if that killed the pcm. Does anyone know of any other way to check the pcm? Thanks
Clayton
