LS into 190e 16v
Old Aug 2, 2014 | 01:20 AM
  #141
clainhart3's Avatar
Hey guys,
Sorry for the lack of updates. I have been pretty busy recently. I have made some progress on the car. I will try and make a post this weekend with some updates.
Here are some teasers
Thanks
Clayton
Old Nov 2, 2014 | 01:37 AM
  #142
84Mercedesguy's Avatar
this inspired me to do my project about doing almost the same swap but instead of the 5.7 ls im thinking about going all 5.3 maybe 4.8 on my build the transmission would probably be a 4l80e but im still in the blue print phase of mine keep up the great work
Old Nov 8, 2014 | 09:52 PM
  #143
mapleridge's Avatar
ive been thinking of doing this to a wagon of the same era.....looks like it is the furthest thing from straightforward.
Old Aug 4, 2015 | 11:02 PM
  #144
clainhart3's Avatar
What's this? Progress?
View this post on Instagram
I picked these up also. Oops.
I also accidentally built this for the BMW. It's a 4.4L M62 with 11:1 compression. Should be rowdy.
Old Mar 22, 2016 | 08:24 PM
  #145
clainhart3's Avatar
Soooo, I'm thinking about selling this project. Is anyone interested?
Old Mar 24, 2016 | 07:51 PM
  #146
DW SD's Avatar
How much do you want for it? Doesn't seem like that much is left?
Doug
Old Mar 27, 2016 | 09:10 AM
  #147
supergcharged260E's Avatar
I love engine swaps, i did a similar swap with my 1987 260E and wanted to give you a heads up about the steering.
The design you have will get the car down the road and will be fine BUT,
you will have a considerable loss of turning radius (1/3 of normal turning) and you will destroy front tires at a fast pace due to the front wheels turning at different angles, there is a science to steering geometry. i know first hand the characteristics your car will have when turning since i have a similar setup that i am working on redesigning. if you have any questions just ask.
Old Apr 2, 2016 | 08:40 AM
  #148
clainhart3's Avatar
I don't think that you are correct.I have designed the steering arm and selected the steering rack to maintain a very similar turning radius to the stock car. I have also taken into account bump steer, would should be almost nothing. So, I'm sure what you are referring to, but I'd love some more detailed insight.
Thanks
Clayton
Old Apr 2, 2016 | 08:52 AM
  #149
Ok well maybe you'll have better luck. how did you decide how far forward and inward of the spindle to mount the tie rod on the steering arm, how did you compensate for the caster angle.
i would love to see it work i have tried 6 different methods that have gotten better but what i found is that there is not that much room in front to rout and operate that much throw which is why i am going to a w210 rear steering rack and changing my motor to a front sump oil pan, it allows for the factory steering arms and the coupling to the steering column is much shorter and simpler.
could you throw up some pictures of the steering rack mounted on the car?
Old Apr 18, 2016 | 01:33 AM
  #150
Razaklsx's Avatar
Are you still selling the car, if so, what is left on the vehicle, and what is your asking price?
Old Mar 19, 2017 | 10:01 PM
  #151
clainhart3's Avatar
https://ls1tech.com/forums/vehicle-c...p-project.html
Car officially for sale.
Old Feb 17, 2020 | 05:03 PM
  #152
Ian Eastwood's Avatar
Default Reproducing your Engine LS1 and T56 gearbox mounts and headers for the Mercedes W201
Hi
Im planning an LS conversion in my RHD (Australia) 190e merc and have some questions for you.
From what I can see you do not cut into the car at all.with these mounts you have designed and I need the same from you delivered to me Sydney Australia if at all possible.
Can you reproduce these engine and gearbox mounts for me and how much?
I also need the headers if you could reproduce.
Did you ever work out the steering rack set up and any words of advise???
Old Feb 17, 2020 | 05:56 PM
  #153
cdk4219's Avatar
You may want to send smoke signals to him his last activity here was in 2018.
Old Feb 17, 2020 | 06:01 PM
  #154
Thanks cdk
I figured as much.
You don't know anyone else that may have his contact details.
Im new to this forum and tried to email him but I didn't have the access.
Cheers
Old Feb 17, 2020 | 07:51 PM
  #155
Michael Yount's Avatar
This in his ad trying to sell the car -- call/text @ 615.five79.five873
