Help! Video- Car idles and revs but not in gear
I finally thought I would be able to go down the street with the new driveshaft installed. I still have an issue as the car will idle and rev out of gear but goes into a "limp mode" when in gear and pedal is depressed. Right now there are NO codes. Also, I have two plugs for the 4l60e (lo and hi range selector?) in my harness but do not have those connected. I have received different opinions about these plugs. Do I need them? I have neutral safety in my shifter already. VSS and trans connector is connected. Any help would be appreciated. Thanks.
98 ls1 with 02' DBW TAC, Pedal, 0411 computer tuned for application..
Have you checked your fuel pressure at the rail? Mine sounded just like that and it turned out to be the fuel pressure. You need about 60 psi at the rail. Can't help ya with the tranny question.Good luck.
