LSx nova project
Old Aug 31, 2011 | 08:16 PM
  #61
Novaman's Avatar
Originally Posted by kwnova9
Carshop 1" setback plates with stock sbc mount attached to it.
oil pan clearance
I'd build a skidplate or take a little out of that pan.
Old Aug 31, 2011 | 09:25 PM
  #62
kwnova9's Avatar
Originally Posted by Tramminc
Hey is that your resume
My resume is better
Fabricating Sno-Cat chassis' and plows at 17 yrs old. I feel like im from a lost generation who knew how to make things with their bare hands.
Old Sep 10, 2011 | 11:07 PM
  #63
Wildkard's Avatar
kwnova9, very nice nova, love how you smoothed out the intake.
I have a 77 I have been wanting to do a very similar swap into for a while now had a motor and trans from a wrecked truck practically drop into my lap today.
I have a couple of questions if you don't mind answering them. Have you tried the truck manifolds? They look like they should fit just fine to me, but it would be nice to know before I start if someone else has used them successfully. Also, I see that you have a cowl hood, any idea how intake clearance would be for a standard hood? I had never thought it would be a problem, but on another forum while doing research someone said it would be too tall for the stock hood, but it seems to fit under fbody hoods so that seems kind of odd to me.
Old Jan 17, 2012 | 08:50 PM
  #64
kwnova9's Avatar
Wow this is a longgggg update. Real story behind why I havent posted since like AUGUST is I forgot my password =[ and for some reason it wouldn't let me recover it....I've been lurking ALOT and been updating my stevesnovasite thread, so to all you at LS1tech, I'll post up PROGRESS!!!
Custom fit shroud made from the stock silverado shroud, still figuring out if i want to run it..
That's right... stock TRUCK manifolds.
This is how the engine will basically look.... currently all the old wiring is gone and i'm finishing up wiring! just need to hook up ground and get my computer back from being tuned.
forming the sump to my tank, ready to be welded
Redid my harness with the help of lt1swap.com
Fuel lines ran
Relay and fusebox I'm using for the harness.
Within the next few weeks I should be able to start it...straight headers, no driveshaft, but hey i'll get to hear her purr!
Old Jan 17, 2012 | 08:53 PM
  #65
kwnova9's Avatar
Thanks! looking back I wish I would have used filler to make it perfectly smooth...
Yes, you have to grind the flanges for them to fit, passenger side has to have 1 of the 3 collector bolts ground off, if it leaks i'll get headers...if it doesn't then AWESOME!
Will fit under stock hood just perfect
Answers above =]
Old Jan 18, 2012 | 07:00 PM
  #66
kwnova9's Avatar
My way of bringing the steam line back to the radiator without modifying my aluminum one...
Obviously will look less bulky once the NPT fittings are tightened all the way!
Old Jan 18, 2012 | 08:39 PM
  #67
brian g's Avatar
Fellow Portlander?
Good looking Nova!
I love small/light cars with V8 powa!!
Going ls1 into 83 Supra....one of these days....
Good progress man.
Old Jan 18, 2012 | 08:51 PM
  #68
kwnova9's Avatar
Brian,
Yeah the Nova is in Woodburn at the parents while I go to school at Western Oregon Univ.
Old Jan 18, 2012 | 09:03 PM
  #69
brian g's Avatar
Good for you, education is a must in todays world.
Old Jan 20, 2012 | 02:59 PM
  #70
dirty94SS's Avatar
wow badass nova great work
Old Jan 22, 2012 | 10:12 PM
  #71
toxic99's Avatar
Makes me miss my first car in high school...my black 77 nova with air shocks and cragars lol. Nice project and good work so far.
Old Jan 23, 2012 | 06:33 PM
  #72
kwnova9's Avatar
Progress....
truck manifolds
Old Feb 6, 2012 | 12:54 AM
  #73
kwnova9's Avatar
It runs! did a startup tonight, even filmed it BUTTT the audio didn't record and its an night so the video is worthless.
Old Feb 6, 2012 | 08:37 AM
  #74
4shearerfun's Avatar
I just read through your entire thread, Awesome work!! There is nothing like hearing the first start up!!
Old Feb 6, 2012 | 09:00 AM
  #75
rouseyss's Avatar
great job man. nice to see you got it running
Old Feb 6, 2012 | 11:50 AM
  #76
kwnova9's Avatar
Thanks guys! When I go home next, I'll make sure to get vids coming!
Old Feb 14, 2012 | 07:23 AM
  #77
cruisin'73's Avatar
Great build man. It is awesome to see someone using thier brain and brawn to build a car and not just up ending thier wallet! I love the use of the stock mech. fan! I had pondered if it was possible. But the advantages of electric fans swayed my decision.
Can't wait for a full road and track report! Subscribed!
Old Mar 11, 2012 | 01:41 AM
  #78
kwnova9's Avatar
Got my Summit Digital Gauges installed
Final mount location for the fuel pump
Video of it running tonight once my buddy uploads it!
Old Mar 11, 2012 | 01:42 AM
  #79
kwnova9's Avatar
Got some more work done today!
Drilled and tapped a port for the Oil pressure sender
Got my Electric Temp sender installed in the passenger head, I used a autometer fitting that I had to drill the inside to a larger diameter for fit the temp senders probe
Digital guages up and running!
Fitted a summit racing electric 120mph speedo where the stock speedo was
Old Mar 11, 2012 | 01:43 AM
  #80
kwnova9's Avatar
Start-up video on youtube!
http://www.youtube.com/watch?v=z5WL2...ature=youtu.be
