Project "White Lightning"
Old Sep 8, 2011 | 02:28 PM
  #41
the_merv's Avatar
Veteran: Air Force
I went down to the shop and spent some time on the press..here's the Aluminum Bushings for the CalTrac Bars and the Bearings on the Eaton TruTrac.
**** them stock Bushings..pain in the ***..lol
Old Sep 8, 2011 | 05:47 PM
  #42
llorracs93s10's Avatar
I got my rear from a salvage yard apparently was a 02 s10 blazer 8.5 rear. I got ebay d/s rotors and use duralast gold pads with stock calipers front and back and it stops pretty good for my truck.
That muscle pan you have, you used the same pan for your mcss? how was fitment on that?
Old Sep 8, 2011 | 06:00 PM
  #43
the_merv's Avatar
Veteran: Air Force
I'm goin with the stock 7.5"..I see it holding up fine..I'm keeping the drum setup on it.
Yea I used that on the MCSS, it fit very well. It hangs below the Cradle about 1.5" at most..I havent had a problem with it, clears the Cradle prefectly.
Fortunately someone already notched the Cradle on this truck..I dont think it'll need it, but I'm not complaining for the freebie.
The guy I bought it from wanted to do a V8 swap in it, just never got around to it. Part of the reason why the original HVAC was removed..
Old Sep 8, 2011 | 06:14 PM
  #44
gotcha thats the pan I was going to go with for my mcss swap. Just wanted to make sure its the best to go with without chopping the cradle up.
And yea man, if you want a v8 s10, no heat or ac is needed....
Old Sep 8, 2011 | 08:16 PM
  #45
the_merv's Avatar
Veteran: Air Force
Here is the Rear Axle bolted in with the CalTrac Race Suspension & 2" Drop Blocks..
To put on the Load Bars I have to wait till the Truck is fully setup and on the ground.
Old Sep 8, 2011 | 08:17 PM
  #46
the_merv's Avatar
Veteran: Air Force
If you look close at the AC Box I got, it's from a 4.3l Truck..it's clearanced from the Factory.
Old Sep 9, 2011 | 09:03 AM
  #47
87DodgeD150's Avatar
looks like its starting to come together pretty well. Hopefully we will be able to tear up some asphalt with it soon.
Old Sep 9, 2011 | 12:45 PM
  #48
TTLS1GP's Avatar
reminds me of my old 4x4 swapped s15 before i bought my yukon.
Lots of jam. 4x4 in the winter was awesome. 4wd burnouts in the summer.
All on stock diff's. who knew! i ran them expecting them to blow so I could convince my wife to let me do a SAS but they never did.
Old Sep 9, 2011 | 07:05 PM
  #49
the_merv's Avatar
Veteran: Air Force
The Transmission is built..Engine is going in tomorrow..
Old Sep 9, 2011 | 08:22 PM
  #50
01cherryreds10's Avatar
This things gonna move out after it gets done spinning. Now.that I finished my car I've been getting the itch to do an S10
Old Sep 9, 2011 | 10:42 PM
  #51
the_merv's Avatar
Veteran: Air Force
I dont see it spinning very much..
Old Sep 9, 2011 | 11:02 PM
  #52
the_merv's Avatar
Veteran: Air Force
Ya I see the Engine going in alot easier than it did with the Audi..lol..
Old Sep 10, 2011 | 08:45 AM
  #53
yeah i can imagine. no turbos. no awd. theres alot less bullshit with the s10.
Old Sep 10, 2011 | 11:41 AM
  #54
the_merv's Avatar
Veteran: Air Force
I yanked the stock Wiring Harness out of the Truck..this thing will be a cakewalk to wire..lol..there is nothing here..
Old Sep 10, 2011 | 08:16 PM
  #55
the_merv's Avatar
Veteran: Air Force
We lifted the Engine off of the Stand and bolted up the Flexplate..
Then bolted up the 4L60E..it has a Stock Corvette 2025 RPM Stall in it..just something small and driveable..
Then it was lifted as one assembly..
The Cab was lifted up about 5" and braced..
I took the Stock Trans Crossmember and welded a piece of steel to it for the 4L60E mount..
Then it slid right in..
The Driveshaft comes about 1.25" out of the back of the 4L60E, everything seems to fit nicely. I have to shim the mount on the Trans about 1-1.5", the Drive Shaft angle is waaaay off, and it will help with the Firewall clearance.
Old Sep 10, 2011 | 09:53 PM
  #56
aircraft chock ftw!
Old Sep 11, 2011 | 03:22 PM
  #57
Skip Intro's Avatar
It looks small in there. Does it really fit that well?
Old Sep 11, 2011 | 04:38 PM
  #58
the_merv's Avatar
Veteran: Air Force
Yea there is a pretty decent amount of side room in there..Firewall is going to be tight, I'm shimming the Tranny Mount to make it fit better and with the proper Driveshaft Angle. I have to replace all of the Body Bushings before I bring the Cab back down, they all blew apart as soon as I hit them with the Airgun. Front wise it's not that bad either..it'll be a tight fit with a LT1 Radiator & Fans, but I see it being doable.
Old Sep 11, 2011 | 05:15 PM
  #59
93Z2871805's Avatar
Veteran: Air Force
aircraft chock ftw!
Lol, time to kick the tires and light the fires!
Old Sep 12, 2011 | 01:16 PM
  #60
the_merv's Avatar
Veteran: Air Force
Me and some friends dropped the Cab back on the Frame. As it sits right now the back of the passengers Head is about .25" from the Heater Box. I'm going to get up in there and grind the corner tab off the Head and smooth it out flush..that will give me atleast .5" clearance at the lowest point. From what it looks like the divot in the box will help with the Coils.
