Project "White Lightning"
Lifting up the cab is a pretty good idea! I realized right away I couldn't stab in the engine and trans as an assembly. I ended up separating them and putting the trans in from below. Gonna try this next time.
And GRINDING!!!
I took it out of the truck so I can sit in the house and enjoy the music, AC, and beer..
Man it was cake to get the cab off..4 bolts. The bed is already off so all I had to do was unbolt the Master Cylinder from the Booster and it was there.
I installed the wiring for the HVAC and ran it through the firewall.
Basically it's stock everything with the Radio intact, some things were re-wired to make it easier. It's setup with the OBD2 Connector, the wiring in the lower left is going to the F-body Auto Shifer that I picked up..it will have the N/S Switch and Reverse Lights fully functional. The wiring hanging next to that are pre-set leads to wire in a Tach. The white C220 Connector near the Fuse Box is what will be plugging into the Engine Harness, every Gauge is setup along with the TCC Lockup Wire for the Auto, aswell as the PCM 12v Fuel Relay Signal. The AC Request Signal Wire is in there so AC can be equipped in this truck..I dont plan on doing it yet. If I do, it'll be there.
Fuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuck.
