Project "White Lightning"
Old Oct 27, 2011 | 12:29 PM
  #261
the_merv's Avatar
Veteran: Air Force
Man, 130mph in that little truck is pushin it as-is..
I can run out more with the T56 in the car..it's got more *** to it to stay on the ground..
Old Oct 27, 2011 | 12:30 PM
  #262
the_merv's Avatar
Veteran: Air Force
Here are some pics of it, it's completely finished..
I'll detail it when the weather clears up..
Here is the complete parts list of what went into this truck:
TRUCK ROLLING CHASSIS: $500
LS1 ENGINE WITH HEADS: $600
CAR SHOP MOUNTS & HEADERS: $331
CAL TRAC BARS: $399
S10 DROP SPINDLES: $100
WATER PUMP: $25
LS1 CORVETTE INTAKE, FUEL RAILS, THROTTLE BODY & SENSORS: $345
LS1 COOLANT TUBES: $36
LS1 INJECTORS & KNOCK SENSORS: $85
TRUCK COILS & KNOCK SENSOR WIRING: $95
LS1 VALVE COVERS & ROCKERS: $99
HEAD BOLTS, HEAD GASKETS, VALVE SEALS, GROMMETS: $145
POWER STEERING BOX & BATTERY CABLES: $58
CRANK SENSOR: $35
MAP SENSOR, INTAKE BOLTS: $33
TENSIONER, POWER STEERING PUMP: $56
LS1 STARTER: $40
PCM & WIRING HARNESS: $304
CAMARO AUTO SHIFTER & LINKAGE: $24
LS1 FRONT & REAR MAIN SEALS: $42
LS1 NON-TCS THROTTLE CABLE: $31
OIL PAN, POWER STEERING PARTS, TEMP SENSOR: $267
Z06 HOTCAM: $90
COMP 7.450 HARDENED PUSHRODS: $83
EATON TRUETRAC: $200
LT1 RADIATOR FAN SHROUD: $20
NEW LT1 RADIATOR: $110
2.5" X-PIPE KIT, MUFFLERS, 2" DROP BLOCKS: $207
CROSSOVER TUBE GASKETS, RADIATOR CAP: $22
WALBRO 255 FUEL PUMP: $100
COMPLETE HVAC SETUP WITH AC: $95
BUILT 4L60E, CONVERTOR, FLUID, LINES, COOLER, MOUNT: $855
NEW POLY BODY BUSHINGS & SWAYBAR ENDLINKS: $94
BENCH SEAT: $40
PCM BRACKET: $10
AXLE SEALS & NEW REAR BRAKE CYLINDERS: $15
28 SPLINE AXLES: $75
OIL, COOLANT, PLUGS, WIRES, BATTERY: $250
INTAKE ELBOW, PIPING, COUPLINGS: $51
FUEL LINES: $13
WIX 33737 FILTER: $50
CARPET: $22
SEAT COVER: $38
HP TUNERS CREDITS: $100
EXHAUST: $310
DOOR PANELS, SEALS, WIPER PARTS: $90
NEW COOPER COBRA TIRES, MOUNTED: $520
MISC LITTLE BULLSHIT PARTS: $130
TOTAL: $7250.00
Old Oct 27, 2011 | 01:04 PM
  #263
Skip Intro's Avatar
Where'd the damn 10-year olds come from?
Old Oct 27, 2011 | 01:05 PM
  #264
merim123's Avatar
I should have said double on my estimate
edit - why is the exhaust on there twice? the exhaust shop charged you 310 to put it on?
Old Oct 27, 2011 | 01:36 PM
  #265
bene's Avatar
Trunion King
Nice runs. I wish I was back in AR. Races here suck. Wait there aren't any races here.
Old Oct 27, 2011 | 01:57 PM
  #266
the_merv's Avatar
Veteran: Air Force
Thanks. I'm pleased with it..
Yea..I bought everything, that was the charge to weld it up.
Old Oct 27, 2011 | 03:11 PM
  #267
Chicago TDP's Avatar
Doesnt it suck how you think you can buy a few things for around $500 each (engine, trans, wiring) plus add in another couple hundred for misc and you'll be under $4K total?
Then you, add up all the BS little things and you basically double the amount?!?
That is the game though, right?
I know it won't (and can't) stop me from making slow cars crazy fast with today's technology!
Old Oct 27, 2011 | 03:23 PM
  #268
87DodgeD150's Avatar
350z floor mats. check
mossy oak seat cover. check
raised white letter tires. check
truck turned out really good.
Old Oct 27, 2011 | 06:49 PM
  #269
the_merv's Avatar
Veteran: Air Force
Nothin wrong with the free floor mats..
Old Oct 27, 2011 | 08:11 PM
  #270
boostnut's Avatar
you do nice work, now get rid of those red door cards.
Old Oct 27, 2011 | 08:23 PM
  #271
the_merv's Avatar
Veteran: Air Force
Door cards?
Old Oct 27, 2011 | 08:27 PM
  #272
merim123's Avatar
door cards = door panels.
I heard it on a UK tv show
Old Oct 27, 2011 | 09:22 PM
  #273
boostnut's Avatar
cards, panels, skins, whateva. the rug don't match the drapes.
I had an old red on red 87 jimmy, can't say that i miss that ugly *** interior. Make it all black or all gray, the mix and match has got to go.
Old Oct 27, 2011 | 11:24 PM
  #274
the_merv's Avatar
Veteran: Air Force
Hey it doesnt bother me and they were the best condition door panels I could find..
If someone wants to buy me some nice black ones I'll put them right in, I wont even charge for the labor..
Old Oct 28, 2011 | 06:00 PM
  #275
gofastwclass's Avatar
Been there, done that.
I say vinyl dye the ones you have... If you're motivated enough to mess with it.
Old Oct 28, 2011 | 07:15 PM
  #276
the_merv's Avatar
Veteran: Air Force
I'm driving the **** out of it as-is..
Old Oct 28, 2011 | 07:36 PM
  #277
LSCustoms's Avatar
I miss the Monte, need more videos and updates of that too! one of the main reasons i joined the forum was the Monte
Old Oct 28, 2011 | 08:05 PM
  #278
the_merv's Avatar
Veteran: Air Force
I'm bolting on some LCA re-locators and 28" Hoosier Drag Radials..not much there..lol
The Drag Rims bolt to both prefect..
Old Oct 28, 2011 | 11:55 PM
  #279
Black98s10's Avatar
That is a sexy monte
Old Oct 29, 2011 | 12:02 AM
  #280
LSCustoms's Avatar
yup very sexy and fast! learned alot in that thread... and this one too
