Project "White Lightning"
So far the MCSS ran a 9.23 1000ft at Centerville..I'm about to get to hook so I see it being in the 8's..
The S10 will run high 9's/low 10's in the 1000ft..I see it hitting that..that'll be the run for your truck..if you can keep up with a little aluminum 346..
Got some goodies on the way for it..about to be in the 10's with the auto in it..on motor ofcourse.
That's why we havent been out in the local crap anymore..we've been hittin the tracks where the fast cars go..
I made an Alternator Bracket out of some extra steel I had..
I'm using the truck 140amp Alternator.
It mounts up nicely..
I had to clearance the Battery Tray. It fits the battery fine..
I'm using a stock F-body Belt too..fits perfect, nice and tight..
Then mounted the Radiator Pads on the Frame..
Then clearanced around where the Cap goes..
That is a LT1 F-body Radiator mounted in there. I just have it inplace, I'm making my mounts for it tomorrow.
I'll have to use some of the aftermarket slim fans, now it's to the point where the stock stuff isnt working..lol..
I'll prob buy a pair of them and mount them on the stock plastic fan shroud and keep the fans I bought as extras for my MCSS.
I thought about it..I'll check it out when I get it running. With a UD Pulley I could see it slipping because of the surface area and leverage, so to speak, on the belt..with a stock Pulley I see it staying tight. That long side is the draw side too..it will pull at that point.
They will be wired in and ran low/high speed like the stock ones..
I still have clearance for the Intake..
