Project "White Lightning"
The wires there are for the shifter and the OBDII Port. I'm looking for some type of Center Console that I can mount that will cover the shifter and have 2 cup holders in it.
That and I have to weld the Drivers Side Backing Plate on to what is left of the broken lower bolts..I was tryin to take them off to clean them up and that was mission failure..lol.
I installed the Eaton Tru Trac Posi Unit..
This truck was factory with 26 Spline Axles, so I went to the junkyard and found a 99 Sonoma that someone had pulled the Diff out of and left the 28 Spline Axles..win.
I assembled the Sending Unit with a LS1 F-body Fuel Pump..I dont see any problem with it working..
In the Gas Tank it went, it is now officially a roller..
It's an F-body Shifter & Linkage.
The Regal Console didnt work out, I'm going to save the pattern plate and make one out of some aluminum sheet I have.
http://www.siliconeintakes.com/produ...b26ae066a090f6
These guys make some bad *** ****..
I ordered it and it will be here in a few days. I was going to try and fab up something on my own..but this will work alot easier. I'm going to go down to the Exhaust Shop and get a 12" piece of 3.5" Exhaust Pipe and get that setup to run the MAF and Filter off of that.
