Project "White Lightning"
Old Sep 16, 2011 | 08:39 PM
  #81
the_merv's Avatar
Veteran: Air Force
Well I kicked the *** out of the Starter and got back to work on it..I found two longer bolts, threaded them to M10x1.5, and put them in. There were enough threads left on the inner to grab it, the outer I had to put a nut on..
I dont **** around fellas..adapt, improvise, overcome.
Here is the Front Suspension all put back on..2" Drop Spindles in the front..
The Power Steering is tight..lol..
The Alternator will be going on the passengers side Head.. I had an extra Truck Idler Pulley and bolted it up. I'll make the Bracket soon, I'm using a Truck Alternator..
Old Sep 17, 2011 | 10:37 AM
  #82
gofastwclass's Avatar
Exactly!!! More people need to live by this!
These projects ain't gonna build themselves!
Old Sep 17, 2011 | 10:52 AM
  #83
merim123's Avatar
that looks really tight for the exhaust, what kind of headers are going to fit here?
Old Sep 17, 2011 | 11:04 AM
  #84
the_merv's Avatar
Veteran: Air Force
I have the Carshopinc Shorties.. 1 5/8" Primaries, 2.5" Collectors.
Should work great for just a little DD truck..
Old Sep 17, 2011 | 11:26 AM
  #85
merim123's Avatar
That is going to be one fun DD.
maybe a remote turbo down the road
Old Sep 18, 2011 | 10:51 PM
  #86
87DodgeD150's Avatar
make it like a derby car and run the exhaust through the hood with 8 flappers on it....rofl
Old Sep 19, 2011 | 03:43 AM
  #87
Black98s10's Avatar
Lol flappers through the hood? I think think that would give the blue haired grandma sitting at the light next to him a heartattack, when he takes off. Lol
Old Sep 19, 2011 | 05:44 AM
  #88
1badeagle's Avatar
That thing is gonna scoot for sure.
Old Sep 19, 2011 | 11:17 AM
  #89
the_merv's Avatar
Veteran: Air Force
I run some everclear so it blows flames through the hood..lol..
Old Sep 19, 2011 | 11:18 AM
  #90
the_merv's Avatar
Veteran: Air Force
Well after several hours of wiring that makes you want to bang your head through the wall..all the wiring is back in the truck and the Engine Bay is fully setup to run the LS1 Engine..
The Fuse Box and PCM Tray were mounted and all wires ran and integrated with the stock Truck Harness, aswell as all power wires are on the Junction Block on the Firewall so the Battery will supply everything necessary with 12v. The C-105 Connector coming out of the Fuse Box will plug into the Engine Harness and will supply all necessary power to run the Engine & Transmission.
Old Sep 19, 2011 | 02:57 PM
  #91
draggin97s10's Avatar
sweet, cant wait to see more.
Old Sep 19, 2011 | 07:18 PM
  #92
the_merv's Avatar
Veteran: Air Force
I bolted the Intake & Coils on and made a Throttle Cable Bracket..
It's a tight fit here on this side..the Coils might have to come off to remove/install the Plug Wires..I havent dropped the Trans all the way on the Crossmember yet..
Old Sep 20, 2011 | 01:17 AM
  #93
the_merv's Avatar
Veteran: Air Force
^^Oh and see owners manual for the proper Oil and fill level for this LS1 S10..
Well I have to re-wire the whole PCM Harness from scratch..I bought it off of Ebay pretty cheap, it was a custom harness that some guy had built to 99-02 F-body specs. It's no where near that, lots of wires in the wrong places on the PCM connectors.
I sent a message to the guy asking who built it for him..this isnt the first time I've fixed "professional" work..
Old Sep 21, 2011 | 12:38 AM
  #94
the_merv's Avatar
Veteran: Air Force
I finally finished the Engine Harness..I had to completely break it down and re-pin it from the bare connectors using some schematics I had. It was assembled incorrectly.
It's now correct and ready to be loomed.
Old Sep 21, 2011 | 08:22 AM
  #95
great work man!
Old Sep 21, 2011 | 08:46 AM
  #96
JAX04's Avatar
Looking good man, thats my next step, re doing the wiring harness, i am NOT looking forward to that, lol.
I hate wiring!
Old Sep 21, 2011 | 03:12 PM
  #97
the_merv's Avatar
Veteran: Air Force
There is probably about 15 hours worth of wiring in the whole truck..
And it's only a single cab..with no options.
Old Sep 21, 2011 | 05:47 PM
  #98
I'm always amazed how much time I spend wiring projects. Wiring isn't hard, but it is very tedious and therefore time consuming and daunting to the novice.
Old Sep 21, 2011 | 05:55 PM
  #99
JAX04's Avatar
Oh, im def a novice, never having wired anything more then a nitrous system and it took me a month to ballz up enough to do that.
Now i suddenly have to wire and entire car, lights and all, and dont even know where to start, LOL.
Its nerve racking and im scared, but whatever, ill figure it out
Good work man, ill be watching as you get her going.
Old Sep 21, 2011 | 06:26 PM
  #100
hogwild1717's Avatar
Thumbs up
Love the build man!! So when you get it on the road lets run'em for fun? Been out playing in my old pick up Oh your prob gonna want more stall, I got 2600rpm on mine right now... God i'm ready for my 3500!!
