Project "White Lightning"
Going in this..
It came with most of the parts, just needs a couple of things.
The 346 LS1 with the Heads was $600, the truck rolling chassis was $500. It has stock 3.42 Gears, I'm putting in a Torsen out of a 2002 F-body to make it more fun. It's getting a 4L60E, Corvette 2250 Stall, 2.5" Drop, Ladder Bars to help..I'm doing the Wiring and Tuning. Headers & mounts are coming from Carshopinc, I've been searching for the parts I need to get the LS1 back up and complete..I have a good bit of stuf layin around already.
The LS1 will be stock with the Headers, 2.5" Duals dumped infront of the Axle..it should move it out pretty well..weight should be under 2800lbs..
The S10 and the G-body cars have the same front suspension/cradle setup..so pretty much what I did to the MCSS will be the same here..
Here's a parts list that I've been putting together so far besides the stuff that I've gotten off of here in the classifieds and what I've had laying around..
Cal Trac Bars
Headers
Exhaust
I'll get Mufflers for it and have it fabbed up to the Collectors. Radiator & Fans will be LT1 F-body..aswell as the Fuse Box. I'm going to wire it simple. I'm still looking into the suspension setup to lower it and have it work good.
If anyone has an idea of Disc Brakes that will fit on the rear then chime in..I'm looking to upgrade them..aswell as the front.
I got ahold of a set of 2" Drop Spindles for $100..prob go with that and get slotted Rotors eventually..have to see how it does with the stock stuff & new pads.
If you don't want to do that you can always do this upgrade
http://www.s10forum.com/forum/f13/dr...32/index2.html
6 posts down for instructions, 4 posts down for a picture.
Your making me want a first gen
I read that Disc Brake install thread..what a pain in the ***..lol..
I'll have to look into it, the Rear is going to be a Torsen out of a 2002 WS6..along with the 28 Spline Axles. I'll cut them to fit if I have to..
Here is the Shortblock prepped for assembly..I bought a Z06 Hotcam for it..218/228, .550/.550, 112LSA..
It's going to be a fast little ****..
