Filling dry 03 LQ9 with coolant
Old 08-15-2011 | 11:04 PM
crainholio's Avatar
Originally Posted by 01cherryreds10
Yes to your second question, just t it in with the overflow hose
There be bad advice here...
Old 08-15-2011 | 11:06 PM
crainholio's Avatar
Originally Posted by speedtigger
I recommend pulling the upper radiator hose from the radiator and filling the block by pouring coolant into the hose. This should only be necessary on the first fill.
What he said. Much easier and more effective than cracking open the cyl head vents. The block will have a reasonably full load of coolant when you crank it using this method.
Old 08-15-2011 | 11:26 PM
LS1 TJ's Avatar
From previous advice from here I drilled three 1/8" holes in the edge flange of the thermostat and it made all the difference on my last dry fill.
Old 08-19-2011 | 09:37 PM
82cecil's Avatar
Thanks everyone. I filled it from the top radiator hose, bled the steam vents.
I ran it for the first time today. fired quickly and ran well with crisp throtlle respone in spite of open headers.
I was searching and found this link from Darkman,
http://www.pirate4x4.com/tech/billav...CoolingSystems
being an LS newbie this is one of the best explanations of the LS cooling system I've seen.
