Having a DBW issue, could use some help.
When I power up the ECM it flutters the throttle plate just a tad. Then when I press the gas pedal nothing happens unless I floor it at which point the throttle plate flutters briefly again and sets a P2138 code. (DTC P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation) From that point forward it won't do anything no matter what I do to the pedal until I clear the code, at which point I can duplicate the issue exactly.
Obviously the pots in the pedal aren't jiving but I find it hard to believe there is anything wrong with it as it is a new pedal straight from GM. The motor was pulled from a wrecked SSR with 23,000 miles on it. Anyone got any advice?
J. J.
J. J.
I'm not the first to use a pedal from a different application. The diagram is EXACTLY the same between the 2 vehicle with the exception of the pin out at the pedal plug. Does anyone else have any suggestions?
J. J.
J. J.
A gunked up TB can also cause a flutter and throw a code.
Other than that, probably the wiring. GM seems to use some black magic when it comes to DBW.
Have you bench tested the pedal to make sure both potentiometer circuits are functioning properly? Try that, and make sure both pot circuits have the same output (as each other) for several different pedal positions, including both at 0% and 100% throttle. If there's a problem there, I bet you'll pick it up pretty quickly. You'll also know for sure which terminals are your +5V, GND, and output signal, which means you'll be able to be absolutely certain you're giving the '05 SSR ECM exactly what it wants to see as per your SSR wiring diagram.
J. J.
https://ls1tech.com/forums/conversio...-corvette.html
There was a little info in this one too:
https://ls1tech.com/forums/generatio...al-donors.html
But I still have yet to find anything definitive. Maybe you know of another thread that I missed?
J. J.
SSR:
"The APP sensors are used to determine the pedal angle. The engine control module (ECM) provides each APP sensor a 5-volt reference circuit and a low reference circuit. The APP sensors provide the ECM with signal voltage proportional to the pedal movement. The APP sensor 1 signal voltage at rest position is less than 1 volt and increases as the pedal is actuated. The APP sensor 2 signal voltage at rest position above 4 volts and decreases as the pedal is actuated."
Corvette:
"The APP sensors are used to determine the pedal angle. The ECM provides each APP sensor a 5-volt reference circuit and a low reference circuit. The APP sensors provide the ECM with signal voltage proportional to the pedal movement. The APP sensor 1 signal voltage at rest position is less than 1 volt and increases to above 2.5 volts as the pedal is actuated. The APP sensor 2 signal voltage at rest position is near the 4 volts and decreases to less than 1 volt as the pedal is actuated."
So I need to find a 5-volt sweep pedal with the correct plug. Thank you.
J. J.
Good luck with it either way.
J. J.
J. J.
J. J.
It sounds like you have a good match, especially based on rockauto. However, it might be worth checking out on gmpartsdirect.com - pull up the SSR pedal and the Trailblazer pedal and make sure they're the same part number. If GM uses the same part number, you have a winner!
J. J.
J. J.
