LS1 Into '72 Camaro!
I've been debating putting an LS-based engine in my car for the last couple years while I've been maintaining my SBC 406. Up until recently it had only been a dream.
Last week I was browsing craigslist and found an LS1 out of a 2001 Corvette C5 with roughly 20,000 miles on it. The engine was complete, minus the PCM, the accessory drive, flex plate, and the TAC module. It came with the complete wiring harness, the pedal assembly, the rails, injectors, the ls6 intake, o2 sensors, exhaust manifolds, coil packs, etc, pictures to follow. I opened it up and it is indeed a new engine. Almost no signs of wear throughout the engine, the cross hatching on the cylinder walls is still very visible. The engine still has the stock spark plugs and they look perfect.
This is the beginning of my build, I still have to get myself a flexplate, for use with my TH400, thinking of getting the TCI part number: 399753, GM flexplate spacer, TAC Module, Computer (have a friend who has one from a 2003 Escalade I might snag depending on some stuff), motor mount adapters, MAF Sensor (going to get a used one from a junkyard or on ebay), accessory drive, and some other stuff.
Here are some pictures of my '72 Camaro and the engine it will be replacing:
And this is what will be replacing it:
The passenger side fuel rail is slightly bent but after inspection the weld held up perfect and I'm going to bend it back to make it straight. The injectors are like new.
More will definitely come as I collect parts and as progress continues!
The Headers
The previous flexplate:
I also picked myself up some Corvette fuel rail covers. I know the engine is going into a Camaro but I felt they were appropriate seeing as the engine came from an '01 Corvette.
I'm dreading the day I pull that vinyl off but I think I'm going to end up keeping it. My plan is to remove it in the near future and assess/replace any rusted areas. I'm probably going to be layering the thing in POR-15 and getting the vinyl put back on.
Its a built 4L80E out of a 2006 6.0L
I purchased a set of Kook's SS Headers, they bolted up to my engine with just a few modifications needed; had to remove my factory AC unit to make room for the passenger side header, I'm going to purchase a Vintage Air unit here shortly so I can retain my air conditioning. I have to pound the corner of my floor board on the drivers side to provide enough clearance for the flanges to bolt together on my driver's side collector.
I plummed my fuel system using half of the previous hard line I had mated with -6AN Summit PTFE braided hose; had to purchase a Summit Racing LS1 Fuel Rail do to the amount of distortion and bending my factory LS1 rail had, I was unable to bend it back into shape enough so that all the injectors aligned properly. I purchased a stock replacement 2013 Camaro ZL1 fuel pump to put into my tank and I had a machinist friend of mine fabricate a mounting ring and o-ring groove to secure and seal it to the fuel tank.
I purchased the Corvette accessory drive kit from a GM dealer and installed that, I'm using all of it with the exception of the AC compressor and bracket, I'm going to sell that and purchase either a S&P bracket or a Kwik bracket with a Sanden compressor.
I still need to purchase myself a set of gauges, I believe I'm going to go with AutoMeter Ultra-Lite 2s as well as purchase or create an aluminum bezel to mount them in.
This is what the engine looked like when I set it in with a dummy transmission (for alignment purposes):
The accessory drive mounted:
Here are some pictures of the headers:
And here is what the progress on the fuel tank looked like:
I filled the tank with water before I started cutting and grinding on the off-chance that there would still be some fuel vapors in there.
I ground the original mounting ring off to make room for the 5'' hole saw to do its work:
I had to weld a piece of metal to the hole inorder for the pilot drill bit on the hole saw to align it and hold it steady:
Heres what the finished mounting system looks like with and without the pump and o-ring installed:
For those that were interested in the build, I apologize for the delay on updating it here, I got caught up in working on it and updating it on Nasty that I forgot to crosspost the updates here.
It looks like you have been very busy. I am jealous that you can do all that yourself. Keep up the good work.
Jennifer T,
GM Customer Care Service
