Superlight 240SX V8 swap
Nice work. Can you post up some cleaner photos of the motor mounts. I am about to throw my 6.0 in a z31 and need some ideas. What bushings did you use? What plates did you bolt to the motor?
Also if you go live axle I want your rear subframe complete
I can get you some close up pictures later of the mounts now that the engine is out.
It's all solid steel, very simple in it's design. Very heavy duty.
I purchased the mount kit second hand so it was all done already for me.
Raylit20, in your radiator / cooling setup, will you be using a heater? Also, what will the smaller heater out fitting (5/8") on the side of the water pump be connected to? I am using your diagram as a basis for a planned swap also. Thanks.
#32
I ended up getting engaged and that took me away from the project. She ran with the LS/T56, but only briefly because of VATS kicking in. Would have been a great car but I sold it because the fiance didn't like me spending time on it.
Now that I'm single I wish I had just parked it in a storage shed and forgotten about it for a while. At least I'd still have it then lol.
#33
Andrew
The following users liked this post:
SupaSupra (09-16-2019)
