turbo 5.3 s10 build
#242
Finished the brakes
![Name: 2012-06-16_13-57-15_656.jpg
Size: 115.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612827d1501332938-turbo-5-3-s10-build-2012-06-16_13-57-15_656.jpg)
![Name: 2012-06-16_13-57-39_616.jpg
Size: 98.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612828d1501332938-turbo-5-3-s10-build-2012-06-16_13-57-39_616.jpg)
Decided to put the gate on and take off the Chevy logo. All of the badges were taken off so it will look more clean.
![Name: 2012-06-16_13-56-48_827.jpg
Size: 108.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612829d1501332938-turbo-5-3-s10-build-2012-06-16_13-56-48_827.jpg)
Need 4 more things until I get out on the road.
1. Picking up drive shaft on Tuesday
2. Tranny dipstick
3. turbonetics boost controller
4. drive shaft safety loop
All easy stuff and i'm pretty sure the base tune is good enough to get it on the road.
2. Tranny dipstick
#244
Thanks man I'll have a driving video hopefully next week once I get the brakes bled.
Got the new drive shaft and boy is it beefy. Its 3.5" all the way with Spicer u joints and pinion flange and yoke. Won't have to worry about breaking
![Name: 2012-06-19_16-59-50_324.jpg
Size: 98.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612768d1501332803-turbo-5-3-s10-build-2012-06-19_16-59-50_324.jpg)
![Name: 2012-06-19_17-11-39_413.jpg
Size: 99.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612769d1501332803-turbo-5-3-s10-build-2012-06-19_17-11-39_413.jpg)
![Name: 2012-06-19_17-12-08_826.jpg
Size: 61.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612770d1501332803-turbo-5-3-s10-build-2012-06-19_17-12-08_826.jpg)
![Name: 2012-06-19_17-11-05_674.jpg
Size: 96.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612771d1501332803-turbo-5-3-s10-build-2012-06-19_17-11-05_674.jpg)
She hates the seats!
![Name: 2012-06-20_18-17-13_126.jpg
Size: 79.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612772d1501332803-turbo-5-3-s10-build-2012-06-20_18-17-13_126.jpg)
Got my safety loop installed. Its not quite within 4" of the yoke but its close
![Name: 2012-06-22_15-26-10_436.jpg
Size: 95.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612773d1501332803-turbo-5-3-s10-build-2012-06-22_15-26-10_436.jpg)
Boost controller ran inside the cab. Easy access for whenever I gotta change boost
![Name: 2012-06-20_18-53-10_761.jpg
Size: 92.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612774d1501332803-turbo-5-3-s10-build-2012-06-20_18-53-10_761.jpg)
Got another dipstick to replace my old pos
![Name: 2012-06-22_15-23-46_643.jpg
Size: 129.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612775d1501332803-turbo-5-3-s10-build-2012-06-22_15-23-46_643.jpg)
My master cut off installed in the bed
![Name: 2012-06-22_15-51-19_469.jpg
Size: 116.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612776d1501332803-turbo-5-3-s10-build-2012-06-22_15-51-19_469.jpg)
![Name: 2012-06-22_15-51-00_864.jpg
Size: 98.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612777d1501332803-turbo-5-3-s10-build-2012-06-22_15-51-00_864.jpg)
Sooo yep that about does it. Its pretty much finished besides bleed brakes, get my ACTUAL drag wheels, and Cal tracs. So in the meantime, I will be taking pictures, videos, and more pictures lol. Need to get it registered And insurence next week then I'll have videos. Stay tuned
#248
It WILL have an LS in it. I have just about everything I need to start the build. I don't want to take the car down till I have about everything I need. I am lacking cam, shifter transmission (long story), driveshaft and mufflers
But I do have a Circle D billet converter, everything else for the motor all the install parts and my 80mm Borg Warner S380 turbo.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#252
Finally got mine in this weekend and i used the stock truck oil pan, but it wont stay running or rev and the VATS were removed and the IAT is reading -37 whether its hooked up or not. running a speed density tune and there is only one O2 sensor. Any idea on what it is?
#253
Get a new iat sensor, that's one of the major components on getting the truck to run right. The iat changes fuel trims, timing, and airflow so it is pretty important to have a good iat. Also, since you're doing sd, Tune out all of the o2 sensors off you aren't using a maf. All you should have is your wideband. Do you have HP tuners? If so go into the scanner and see what all your sensors read to make sure everything is on track and check timing also. And Freeman, the best part is she ******* hates it! Lol. She loves me
#254
#255
Hmmm. Well I would need the connectors with it so I could hook it up to a battery with a diagnostics port to tune it because I have blue red connectors so I couldn't hook it up to my truck. And then since i'm not an actual "tuner" I would need to buy $200 just in credits so I could tune it because I don't have the unlimited GM credits like the actual tuners have. So it makes it a mess lol. Since your iat is reading -37 it can't be o2 related so it has to be a bad iat. I would start by replacing that.
#256
so i been driving my truck the past couple days and heres what i have come up with so far.
heres what my intercooler piping looked like the first time i did it
![Name: 101_0022.jpg
Size: 181.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612700d1501332653-turbo-5-3-s10-build-101_0022.jpg)
well that ended up hitting my wheel when i took right turns, so i changed it to some flexible plastic **** from oreillys just for a quick temporary fix to i could drive the damn thing.
took it on the road and the intercooler pipe off the turbo blew off so i tightened that after i got back and its on there now so no big deal. opened the hood and found this
![Name: 2012-06-28_17-29-27_896.jpg
Size: 125.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612701d1501332653-turbo-5-3-s10-build-2012-06-28_17-29-27_896.jpg)
yep, had a feeling this would happen. in the mean time, when i took it out for the first time the afr was great and seemed to be running good besides my tranny was messed up and first and second gear ended up being in drive, my drive was pretty much in neutral and wouldnt go, and my reverse sometimes engaged in the right position, and my park was fine so i couldnt really shift it like i wanted it so it never really made it into boost and it always automatically shifted.
so i got a 90 degree pipe from napa and ended up with this
![Name: 2012-06-29_20-32-27_532.jpg
Size: 120.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/612702d1501332653-turbo-5-3-s10-build-2012-06-29_20-32-27_532.jpg)
yay! no more boost leaks. took it out on the road, and i actually got it into boost in first gear and it started spinning the tires. im running on the gate spring right now and forgot to check boost pressure but its only at 9lbs and i shifted around 5000 and then it was in auto after that so i couldnt actually run it. later on down the road i lost power steering and then the afr went way lean and the truck killed it self so i parked it in a church lot.
opened the hood and heres what it looked like. the lower radiator hose pissed fluid all over the place, therefore causing the belt to rip and fly off. so i was losing battery and it overheated causing it to go lean and retard until it killed itself. so hopefully within the next day or two ill have the lower hose fixed and a new belt and im going to play with the shifter linkage to see if i can get the tranny working right. im hoping the tranny aint shot because it was just rebuilt and it better not be $1200 down the drain. once i get it going ill for sure have a video once i download the new tune (the current tune is around 20* advanced wot) and run 15* at wot so i can get the thing to pull *** and turn the boost up. ill keep ya posted on whats up
#257
Damn what an ordeal. Good luck getting all the bugs worked out. **** like that always seems to happen with major changes. I remember on my last turbo build with my sti, sarg and I were tuning and on the first full boost pull a coupler popped off at 20+/- psi. I thought I blew the motor it was so loud.
