Code Confusion
Old Aug 30, 2011 | 07:58 PM
74novacustom's Avatar
Default Code Confusion
So this weekend i started driving my car. I got maybe 40 miles on the car when out of nowhere there was no response to pressing the pedal. It even idles lower than normal. Ive got a scanner so i pulled the codes and cleared them out. once i start it, it just idles lower than normal and the codes are right back.
Here are the codes.
P1516
Command VS Actual throttle position performance (Tac Module)
P0120
Throttle/Pedal Position Sensor A circuit
P0220
Throttle/Pedal Position Switch B Circuit
P2135
Throttle/Pedal Position Sensor/Switch "A"/"B" Voltage Correlation
Now ive done some research and ive looked at my Yellow wire that hooks into my TB, i traced back about a foot and its fine.
Im thinking some sort of Hardware Failure, Its a New Pedal Assy. not to count that out but i would look at that last. The TAC came with my harness and engine. The TB was bought used and modded to fit my water pump, the Water barbs underneath it have been cut off.
I was thinking of just replacing the TB, but i figured id ask some of you before i waste money.
Thanks for looking
Old Aug 31, 2011 | 08:12 AM
46Coupe's Avatar
I'm dealing with this right now as well.
I'm reading:
P0120
P0220
P1125
P1516
P2120
P2125
P2135
P2138
All my stuff is from a 2006 Silverado with DBW. TAC, Pedal, TAC harness, computer, and throttle body. It is throwing every DBW it can.
From what I have read through searching here is that there can be several causes.
Bent or corroded pin on the TB, pedal or TAC, a broken wire, a bad ground that is not letting the proper reference voltage through. I'd check grounds first, even if they look good, clean them off again.
Mine problem persists and I have Jon at PSI looking at the hardware to see if he can troubleshoot it better than I.
I'll let you know what I find out if you haven't solved it by then.
Old Aug 31, 2011 | 10:07 AM
I'm reading:
P0120
P0220
P1125
P1516
P2120
P2125
P2135
P2138
Will do, ive looked over the harness and the pins on the plugs, everything looks good, i just finished my grounds days ago and they were done with extra care, but i will look again.
Old Aug 31, 2011 | 10:17 AM
TomM's Avatar
Sounds like a blown fuse....
T,
Old Aug 31, 2011 | 10:18 AM
hookemdevils22's Avatar
Re: P2135
Here's some better info. Seems to be the TAC or TB.
Old Aug 31, 2011 | 10:36 AM
T,
I checked all the fuses that came with the harness from Current Performance, i didnt check any fuses from the car itself though.
Old Aug 31, 2011 | 10:40 AM
Originally Posted by hookemdevils22
Re: P2135
Thank You, Those were some good reads. and i agree with you either TAC or TB.
Old Aug 31, 2011 | 11:08 AM
psiconversion's Avatar
LS1Tech Sponsor
74, what is the engine application? What transmission are you running?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Aug 31, 2011 | 11:16 AM
Jon
PSI
The Engine is a LQ9, with a 2005 5.3 Harness and computer.
Trans is 4L60E
Old Aug 31, 2011 | 11:19 AM
LS1Tech Sponsor
Does the throttle body have two connectors (6/2) or one connector (8 pin, stock on a 2005)?
__________________
Ebay Store
Old Aug 31, 2011 | 11:25 AM
Just one
Old Aug 31, 2011 | 06:33 PM
I guess if i get really ancy this weekend i can just use my escalade as a parts doner to find my problem.
Old Sep 1, 2011 | 11:54 AM
Re: P2135
Im thinking the P2135 was from me unplugging and testing things, i cleared the codes and that code didnt come back.
Old Sep 2, 2011 | 11:53 PM
Woohoo, I got it figured out, I swapped out the TAC module from my escalade and the Nova came back to life.
Old Sep 3, 2011 | 02:31 PM
thenova70ss's Avatar
GREAT job man thats how to use your head and part from your Escalade to bring the nova back form the dead.
