89 240sx
Old Sep 2, 2011 | 03:15 AM
dm79's Avatar
Default 89 240sx
well i have a build thread going on silviav8 and figured i would start on here since im pretty deep into the build. Although i have hit some major snags.
It all started with an 89 coupe i picked up off craiglist a year ago for $700. i always loved the style of the coupe
2000ta ls1 pullout with t56, some no name headers, bbk80mm tb, ls6 intake, and pro5.0 shifter for less thank 3k.
Old Sep 2, 2011 | 03:18 AM
dm79's Avatar
radiator came in
fpr ready to rock
parts start piling up
patriot extreme springs going in with a double roller timing chain
donkey dick cam custom grind (close to g5x3)
Old Sep 2, 2011 | 03:20 AM
dm79's Avatar
bought this to battle the 107 degree tx heat, the front has a mister lol
balancer coming off
she is open
Old Sep 2, 2011 | 03:22 AM
dm79's Avatar
donkey dick cam going in with home depot lifter tools lol
double roller is on
dot to dot, spun it more than 720 degrees, everything still lines up
fueled pan just came in
Old Sep 2, 2011 | 03:24 AM
dm79's Avatar
test fitting the pan
Hushpower muffler just came in
Old Sep 2, 2011 | 03:26 AM
dm79's Avatar
yanked the engine and started to work on bay
primered up
made the radiator support removable and laid down some black
Old Sep 2, 2011 | 03:28 AM
dm79's Avatar
Test fitting the engine
shifter sticking way up into tranny (more on this later)
driver side with Ottov2 mount
passenger side, see oil pan? Houston we have a problem..
Old Sep 2, 2011 | 03:31 AM
dm79's Avatar
shifter location
its in
with the tranny tunnel beat to hell and the tranny pushed all the way up in the hole i get this kinda clearance on the tb
firewall clearance driver side
passenger side... very tight
Old Sep 2, 2011 | 03:32 AM
dm79's Avatar
stock gto header looks like it will work if spaced out a hair
Old Sep 2, 2011 | 03:35 AM
dm79's Avatar
Now the major problems. these mounts where made with a stock gto pan. Im using the fueled racing moroso pan. i think in combination with my chassis cross member being a little diff than s14 guys and my oil pan. its not clearing. these mounts have been used with good success in s14 with moroso pan.. mine its not happening
this is the angle my engine sits with these mounts and tranny pushed up all way
engine sits super high.. almost too high. oil pan does not even sit below the sway bar. i also have 1" from pan to top of steering rack. you may think this is not a bad thing but more to come
Old Sep 2, 2011 | 03:38 AM
dm79's Avatar
i thought about slotting the motor mounts since i have so much room to drop the engine down and get hood clearance. but if you look at my motor mounts, the clamshell is resting on the support brace.. I cant slot them, the engine would not drop anymore
I also thought i could slot the mounts to move the engine forward at least a half inch to give the pan to crossmember clearance some room... Cant do that either, i would have to slot it so the bolt would come towards the camera. this is from under back looking forward. theres just not enough space
Old Sep 2, 2011 | 03:41 AM
dm79's Avatar
passenger side same thing, cant slot the hole to drop engine, clamshell is maxed out on mount
so now i have just ordered these
http://carshop.carshopinc.com/produc..._id/86960/2350
I hope i can figure something out and get these either welded up to the stock k member or frame. I suck at welding. So if all else fails ill have to higher someone to come over and do it for me. This should work so that i can position my engine lower and little forward....
Im hoping.. this build has been a fight since the beginning...I just want it to be over with lol
