Turbo ly6, 70' Chevelle....Pics...
Old 09-27-2011, 05:07 PM
74novacustom's Avatar
Wait.. holy crap you have a Chevelle. Ive looked at this post a dozen times and didnt get to the car pics. the first pic of your grrrrrtuurboooo yeah turbo had me stopped there.
Old 09-28-2011, 08:53 AM
chevellepowered's Avatar
[IMG][/IMG
yes it is a chevelle.. lol. .. same gear you must be running a b.o.p. rearend... im hoping it does well..
Old 09-28-2011, 09:21 AM
boostnut's Avatar
more girlfriend pics, less car pics
Old 09-28-2011, 10:44 AM
$O$OE's Avatar
This man speaks truth..
Old 09-28-2011, 11:17 AM
Chicago TDP's Avatar
Pictures of girl or fail....
Old 10-06-2011, 03:33 PM
well what was i gonna do with the fuel supply.. been rackin my brain for days.. i didnt want a fuel cell in trunk like i did before.. i wanted to oringinal tank back in the car.. more trunk space.. etc.. so i came up with a redneck solution.. I do a lot of a/c for houses.. so i choped up a r-22/freon can in half..And going to cut/weld in a 1/2 inch coupling in the can.. it'll work for a fuel sump.. dont kno how low its gona hang .. and for the top im using a cap,incase i have to add another 255 walbro in there ..or change out old one. i used some shet metal of old air handler..i scraped awhile ago...i had to have a flat surface to mount the cap..i can still use the original sending unit.. im debating on making a removable trap door above the freeon tank.. i could easily remove two bolts , from access where cap is ..to work on adding/removing fuel pumps..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 10-06-2011, 03:47 PM
Im waiting on motor to get back from machine shop,,had them install new cam bearings.. i went to install the ls3 cam.. it had a lil nip on the cam. didnt see it.. installed cam..tight as hell.. wouldnt spin over.. pull it back out.. i felt it cut into bearings.. and saw metal shaving.. did not run motor. .. . pulled motor out..apart and having them install the bearings..i'll assemble it soon as it gets back.. and having them polish the cam ...
Old 10-06-2011, 10:37 PM
gearhead65's Avatar
Sucks...
Old 10-09-2011, 04:05 PM
2165 Turbo Rail's Avatar
I like it.. I hope your pass side plugs are easier to change then mine! I had to change mine on the dyno one time... SUCKED!
Old 10-09-2011, 07:51 PM
slocaddy's Avatar
DO NOT PAINT THE FREON TANK! Let me know when you want to come down to sarasota and turbo the caddy. very cool build
Old 10-09-2011, 09:11 PM
I used an external fuel pump... I'd go that route before doing the home made sump
I started with a Walbro 255 but after a couple of those failing I have changed to a Bosch 044
Old 10-09-2011, 09:37 PM
  #32
yes i made very sure i could get to the plugs easily... i had to chnge them out one time on the dyno toowith my old turbo 5.3 setup.. pain in a$$.. this time there very easy to get too.. i dont think im goin to paint the freon tank. ..like to get reactions from when they see it.. ..i havnt had any problems with a walbro intank.. had them before they ran great.. .i bought a 3/8 threaded steel tube.. cutting/welding it in freon tank. ...i will be happy to turbo your caddy..seen one run on the dyno/youtube made low 600's to the wheels..stock.with upgraded fuel system..it was a 2010 model..
Old 10-24-2011, 10:01 AM
  #33
[IMG][/IMG]
[IMG][/IMG]
thinking about replacing that dryer duct with 4in alum piping.. im going to run a metal screen right in front of turbo.. for filter..
Old 10-24-2011, 10:03 AM
  #34
update.. motor is all back togeather..in car,, still needing 60lb injectors, and lil misc things.. nickel and dimes.. ls3 cam is installed.....And i am considering on not running an intercooler,,just spraying alot of straight methonal.. right into the turbo.. maybe running a duel squirters... one, pre turbo, and other in the charge pipe..
Old 11-02-2011, 09:19 PM
  #35
[IMG][/IMG]
update.. 65lbs injectors on there way.. .. finished up the fuel system.3/8 hard line.. . i need to do a lil more wiring.. cold side is pretty much done.. few more small stuff.. blow off valves..etc.. still need to route oiling for turbo.. just about ready for tune.
Old 11-02-2011, 09:25 PM
  #36
Project GatTagO's Avatar
Received 1,442 Likes on 910 Posts
What the **** is that in your upper radiator hose?
Andrew
Old 11-02-2011, 10:51 PM
  #37
redhotev1's Avatar
Default build
Awesome!!!!
Old 11-03-2011, 11:26 PM
  #38
yes upper rad hose.. the radiator is tight outa veiw.. no access to the cap.. and it was good way to route the steam from head out..
Old 11-05-2011, 01:34 AM
  #39
slownova73's Avatar
hmm, I LIKE IT! nice work!!
Old 11-05-2011, 12:12 PM
  #40
Please take that crap off and do it right. Here is a nice overflow tank kit that may work:
There are a lot of other tanks out there.
Andrew
Quick Reply: Turbo ly6, 70' Chevelle....Pics...
