ls1 gto wiring and ecu
new swap, new problems. i havent done this in about 2 years. another drift car ls1 build but this time i have ls1 gto 2004 motor, no harness, no Ecu.
Question:
1) can i use f-body ls1 harness and ecu?? finding ls1 gto wiring harness and ecu is proving harder than i thought.
2) if it i can, using ff-body accessories - power steering pump and alternator it should be plug and play?
thanks in advance
Question:
thanks in advance
LS1Tech Sponsor
GTO used a green/blue PCM while the F-body used used a red/blue, O2s will be different as well. Go with the F-Body stuff.
Jon
PSI
Jon
PSI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic84531_2.gif)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Question:
thanks in advance
Question:
thanks in advance
