duramax or cummins
Old Sep 27, 2011 | 04:33 PM
59 camaro's Avatar
anyone have a idea on what a custom swap like this would run?
Old Sep 27, 2011 | 08:32 PM
89 formula350's Avatar
http://fordcummins.com/
Old Sep 28, 2011 | 04:16 AM
One Bad Duramax's Avatar
cummins and you can tell i'm a duramax guy
go for a 12v or 24v
Old Sep 28, 2011 | 10:59 PM
retardedpenguin's Avatar
About $10,000 for a shop to do it. If you do it yourself, $3500-$5000.
Old Sep 29, 2011 | 06:59 PM
zeke5551's Avatar
Default Got a 4BT on the West coast
I haven't read your entire post yet, but a 4BT is a very simple swap and very popular with all the rock crawler guys. A scock engine will give an easy 350lbs of torque. I just happen to have a low hour 4BT set up for a Chevy bolt pattern. I was putting it in my 55 Chevy Cameo PU, a light 2 wheel drive conversion will pull 30-35 mpg, easy. My wife said she'll never drive in it if it smells like diesel. After 3 TDI Jettas and a Cummins powered Dodge, I realize it can't be done. There is no way I can seal up the cab on a 55, so out it comes and in goes a 5.3. The engine comes off of a 900hr back-up generator for a ranch. It runs exelent and is barely broken in. I set it up with a Chevy adapter, manual trans flywheel, 12 inch chevy clutch, 26 spline disk. I have a new truck style oil pan and pick-up. The real trick is to find a virgin engine without any repairs with non-Cummins parts. This engine has never even been washed down. I have $3,000 into the engine. If you don't want the Chevy stuff, I will take off $500. 6BT Dodge/Cummins 12 valve stuff bolts right on, so if you don't mind a 47RE auto trans its an easy, bolt on conversion. A NV4500 Dodge is another good choice if you want to go a Dodge manual trans. You can email me at zeke5551@comcast.net or 559-9077240 I live by Fresno, CA
Old Sep 30, 2011 | 01:26 PM
Black93GT's Avatar
My previous truck was an F250 with the 7.3L. I liked the truck til I had too many problems to deal with... So I bought a Dodge with a Cummins. Minus the little problem of it being in a dodge, it's an awesome truck. My fuel economy is far superior to the F250.
I see cummins with tranny posted on craigslist quite often. And if you don't want the strong diesel smell you can always use a catalytic converter. Those can be found on craigslist from time to time.
Old Sep 30, 2011 | 10:44 PM
dogger's Avatar
94 to 98 12v are by far the easiest to swap and make good power and good fuel economy. the 4bt is harder to find and normally a little bit more money. i would stay away from the common rail swap if you want easy because you need the computer and a harness to make them work. btw 6bt would easy fit in a gruman if thats what your doing 4bt was a option in some of them. cost wise there are a lot of factorys including buying a complete donor but if you find a complete 12v and tranny it will prolly be the cheapest route as a 12v only needs a couple wires hooked up to run.
Old Oct 1, 2011 | 12:22 AM
59 camaro's Avatar
thanks for the help but i wont be buying the truck afterall.......managers at work wont allow me to use it for what i want to
Old Oct 1, 2011 | 12:31 AM
97badass's Avatar
if you do a cummins go for the 12v, or a 4bt. the ag engines are cheap to come across and not hard to make work.
stay far away from the common rails.
Old Oct 1, 2011 | 12:11 PM
Diesel smell? I have two 99 7.3's, an 04 6.0 and an 05 cummins. None had that diesel smell.
