G Body P/S Pump Question
Find a stock steering box and pitman arm for a g body.. get 1in setback mounts and voila! You can run factory clam shell mounts, with 1 in setback and the factory truck ps pulley clears by about an inch.. plenty of room. I'll snap pictures later when I get home.
Sell that manual box as a lot of f body/g body guys that have drag cars would like it.
I think you may have read my thread with the wheels turning opposite the steering wheel. Turns out that my hoses were in the wrong ports on the box. Odd thing is that the stock G-body box has 2 different sized ports and the pressure line fit the return port for some reason. To solve my problem I bought a manual box until I have better access to my car to tinker with non-essential issues.
NOTE: I say "should" because I do not know this will work from first-hand knowledge seeing as mine was a bit messed up and I took the easy way out. I do, however, know how to take the valves out as I did actually do this step.
You may have to copy the url and do it manually
http://www.facebook.com/photo.php?fb...type=3&theater
