wanna make a chevy stang! need advice.
hey guys im new at this chevy in a stang thing and i have a few questions to ask all u PROS! i have a 88 notchback that i wanna maybe do a lq9 motor in im just wondering what i need to install this into a fox i really want it fuel injected but i heard carb'd is the way to go im looking to get at least 600+ horse i kno the block can handle 1000+ so im gonna put a rotating assembley in it..with the newer escolade heads and a nice cam...i want the motor to be able to handle a good shot of juice cause this is gonna be my street money maker car. it already has a built 8.8 with strange axels spool 5 lug convert and c clip elim's and a ugly *** paint job but i run a bodyshop and do paint and body so that dnt bug me heres a few pix of it..
the easy way to go about with the swap is get aje k-member and mounts. they also carry the trans x-member. get a set of 302 or 351 long tube headers, cut the ford flange off and weld on ls flanges. i used 302 headers. drive shaft will have to be made. are you planning on using power steering? if so there is a valve or fitting on the gm pump that needs to be swapped. the truck accessories should fit under your cowl hood. the ford radiator can be used or you can use a radiator from like a 98 camaro. as far as which route you go as far as carb or efi, you have several options for each. let me know if you need any more help. i have done a 89 hatch and a 94.
maybe someone else will chime in but i think you will need the flaming river manual steering rack and a different steering knuckle.as for going efi, i don't know the cost. for carb, intake $269, box $309, a good carb preferbly a double pumper, and a return style fuel regulator $70. u can get all these from street side auto.
where do i get a harness that would work with a lq9 in a fox? ive been researching and i kno where i can get everything but the harness im decent at wireing i useto install sound systems and roemote staters at abc warehouse so i got wireing down pretty good...are they easy to make and where can i det the ''how too'' directions?
Sorry to say, But utilize the search button. There are TONS and I mean TONS of threads on this subject. Ive read a lot and trust me its worth reading. Im sure you have a ways to go so might as well get started on some reading. Ask questions when you run into a issue..
