e30 5.3/cts-v tranny clutch problems
my setup is a 1989 bmw 325is with a 5.3 and a cts-v t56... i bought a ls1 clutch setup with the same slave cylinder out of a fbody... i bleed everything and i have no pedal... from what i read.. you can use the same slave as the one that you get the clutch with with out using a spacer...
do i have to use an ls7 slave cylinder... or do i have to use a spacer???
thanks for any help
thanks for any help
also... i have a 5.3 pilot bearing in it right now and it all mated up just fine and feels fine on the road but could this be wrong... and if it is wrong would it even mate up??? do i have to use the cts-v pilot bushing???
Well all the parts are good.. I did some research and looks like I need a spacer to get the slave to contact the clutch fingers. Would anybody know the exact thickness the spacer needs to be.
