My turbo 4.8l 87 IROC build
Old 03-18-2012, 03:29 PM
  #161
sniperperformance's Avatar
great job thus far. dont be afraid to wrap those headers. there 310 stainless and there .100 thick tubing/pipe. they should take a beating. i forgot to tell you that when i built those i modded the water neck to point down. great job.
Old 03-18-2012, 05:19 PM
  #162
RPD_Vette84's Avatar
thanx yeah they worked out great. we got everything to work. i didnt even know he was goin to wrap the stuff he did. i was goin to have one of my buddies wrap everything for me.
Old 03-18-2012, 05:45 PM
  #163
Old 03-19-2012, 10:14 PM
  #164
Beatdown Z's Avatar
Nice exhaust work!
Old 03-20-2012, 12:21 AM
  #165
LSCustoms's Avatar
awesome, only thing i would have added would be an electric cutout... but amazing work and inspirational to those wanting to tackle something like this...
Old 03-20-2012, 01:51 AM
  #166
Theres an electric cutout goin there just havent bought it yet. And thanx
Old 03-20-2012, 02:58 PM
  #167
LSCustoms's Avatar
sweet! im loving the whole build, if you wanna take on another pipe fab job, pm me with an estimate, for something similar on my 84 el co... i have a built motor, and was going to attempt the fab myself, but i honestly like how yours came out... i just need the stuff in the engine bay done, i can do the cut outs and part under the car to the back, cause doing something special there...
Old 03-20-2012, 09:13 PM
  #168
oh i didnt do the work. i have a great exhaust guy that did it all for me. i wish i knew how to weld and that stuff.
Old 03-20-2012, 09:25 PM
  #169
Daniel0026's Avatar
Where are you planning on going through the firewall and/or fender? Thanks for keeping us updated! subd!
Old 03-20-2012, 09:53 PM
  #170
Old 03-21-2012, 07:38 PM
  #171
remember its not done yet. i still have lots to do.
http://youtu.be/g9Pz791zV84
Old 03-21-2012, 09:06 PM
  #172
Bigdeezs's Avatar
sounds good...idle kinda high?
Old 03-22-2012, 01:11 AM
  #173
yeah i think its cause the fast TB.
this is how the throttle body is. i need to find a new blade or something
Old 03-22-2012, 05:38 AM
  #174
Bigdeezs's Avatar
is that stock or did someone port it? Maybe you could fill in the gap with a thin layer or JB weld or something around where the blade should seal.
Old 03-22-2012, 09:32 AM
  #175
Stock. Its a first gen. I guess they were known for having issues.
Old 03-22-2012, 11:25 AM
  #176
2sslow2win's Avatar
glad you finally got it running, been watching this build for some months, inspiration to get mine finished looking to make 5xx on pump gas, good luck
Old 03-22-2012, 07:36 PM
  #177
thanx. whatcha buildin?
Old 03-22-2012, 08:27 PM
  #178
kmattinson67's Avatar
That would be a pretty easy part to have a machine shop build you.
Old 03-29-2012, 04:48 AM
  #179
Firehawkslplus's Avatar
Default DIY throttle blade
I agree You could even do it yourself. I'm sure the screws are staked on the back side to keep them from coming loose (just like a Holly throttle plate). So from the back you grind the staked part off and the take the three screws out. Measure the ID of the throttle body at the point the blade fits. Now you can either make a pattern on some paper or draw it directly on the metal. Next get a regular old school compass ( you know point on one end; pencil on the other) set the distance between the pints at half your diameter and draw a circle. I would lay the old throttle blade down on your circle center it up by eye and mark the mounting holes. I'd make them just a tiny bit bigger to give yourself a fudge factor. If it's not perfect get it close then take a Sharpie color the the contact area on the inside of the barrel and the outer diameter of the the new throttle blade. Bolt it up work it a few times look to see where the marker rubbed off those are the spots that need your attention. One last thing round the edges; this will make it easier to handle and less likely to hang up ect. O.K. one more last thing locktite the screws.
Sorry just had an Idea and got carried away; not trying to tell what to do. But based on what you done in just this thread I real do think this well inside your skill set.
Old 03-29-2012, 06:04 AM
  #180
BullyDawg's Avatar
Great build! Just read through all 9 pages! I am going to build a boosted LsX one of these days, just not sure what I am going to put it in yet. Maybe my 5.0, but meh.
Quick Reply: My turbo 4.8l 87 IROC build
